Ride_Red 2000 Limited Build Thread
Just scored another Sport Hood, but this one is painted already!
Other one is now for sale in the classified section.
$200.00 local pick-up in South Jersey.
461AD06C-1CBD-4FE0-9083-BB037C5AFAE5-468-000000577649DB71_zps76d67fdc.jpg~original
E5E447E8-3F2D-43EA-8132-77B6DC7E0361-468-000000577E098E93_zpse66e06b6.jpg~original
nice score on the sport hood!
when you installed your Spidertrax 1.25" wheel spacers/adapters, did you use any Loctite?
and how often did you recheck the torqued lug nuts to ensure they did not loosen?
have you noticed anything with regard to your axle seals?
Thanks!
Yes, loctite came with the spacers. Only had them on for a few months and I have never checked. Prob a good idea when it's warm again?
No issues with axle seals.
I like what you've done with the truck! Am I to understand you're keeping the running boards on? J/k ;-)
Btw, I have that same GNU (Rider's choice) and LOVE it. I'm a big fan of Mervin Industries stuff - I have the Gnu and a Lib Tech T-Rice deck for big mountain stuff :thumb:
Also, your wife is awesome, apparently.
Thanks Fish!
Mervin boards are awesome! First board I ever owned was a Lib Tech Jamie Lynn. I took it to Big Bear/Snow Summit out in Cali after the X-Games one year and came up short on a water gap and she snapped. Even though the board was over 2 years old, they replaced it for nothing! Since then I owned obviously, (2) Jamie Lynn's a Joey Mcguire and now my Pickle Power GNU.
I see you have a little DT250, check out my YSR collection.
DSCN2045.jpg~original
9th mod
Sport hood install:
Couldn't wait so I had my brother come over and help me with this in the middle of the night.
Very easy with only 4 bolts, but I needed a second hand to line things up.
2B382519-9C36-4A64-861E-677EBF65F06D-3780-000003907CEC400B_zps5ceaf595.jpg~original
25C13DC0-7571-434F-BAB3-1D200F4A2FAF-3780-00000390805C406A_zpsa93f69e0.jpg~original
43121621-03F0-4930-B8CA-0C8C5F7DBBFA-3780-00000390836B2679_zps0c91a05e.jpg~original
Here it is next to another 4Runner @ Wawa.
D414F6FA-C85C-4FE5-B899-FD9995F8F1BB-3780-0000039094D0E351_zps09aa6039.jpg~original
On top of scoring the sport hood, I managed to get another mirror (mine had a slight crack), set of OEM lights (for me to complete my retrofit) and a set of 02' rear tail lights.
5FF75DF8-9349-4453-8748-0524B14A6423-3780-000003921EE7C1BE_zps7fdd6c7a.jpg~original
Here was the donor truck R.I.P.
The truck in the back is where I snagged the tail lights from.
118D886A-ED68-49B4-961D-FDFDB84504F0-3780-0000039221FC1932_zps30fd6c68.jpg~original
10th mod:
2002 tail light swap
I didn't know the bulb sizes were different? I ended up having to switch out the top light and trim the tab on the middle light to get these on.
Before
9439053B-038C-4F8D-8F43-7DE66D1CFC4C-3780-0000039088AAE723_zps0f841122.jpg~original
After
437E3F37-11C6-437E-9C81-7ECDD0D50DF7-3780-000003908EB00832_zps7feb1846.jpg~original
6604C521-BF24-44C4-9A05-FA1CD3F76184-3780-00000390866165FB_zpsf391e136.jpg~original
59080A05-F696-46E0-A7AF-833A02024483-3780-000003908BAEB645_zps5c0066d2.jpg~original
Since I personally think the 890s are little too stiff and some are saying the LX's maybe too soft. I picked up two sets of LC coils. I figure if I don't like one set, then I'll swap them out. Better to have options.
Went to a LC parts yard to pick these up. Wow, they had a lot of cool stuff there! Almost picked up a set of 9 wraps just cause they were there. Hope to have the LX's on in the next week or so.....
20.25" Blue Yellow White 8.75 wraps-one of these is a confirmed LX450
19.5" Green Yellow White 8.25 wraps-one of these is a confirmed LX450
19.5" Purple Green White 8 wraps
19.25" Double Purple Dark Blue White 8 wraps
4B622729-749B-4F97-BC1D-DAF4CB937AE6-2591-000002253315E949_zps598e3efa.jpg~original
2358A8B0-9C96-4512-8708-C346E2D1B971-559-0000006E15647313_zps3cc39741.jpg~original
Ton of LC wheels and other parts
E9905F6C-2389-4891-9D69-77DE2C97A34D-559-0000006E189FCFAE_zps521488eb.jpg~original
6E609346-7336-456F-8B3E-FD1C4FF5B4F8-559-0000006E11E85302_zps39aa90b6.jpg~original
7DAFA63A-C071-49D6-A1F5-1B319C78A6C5-559-0000006E0EC00802_zps8e5856d1.jpg~original
8F331F0A-F5A6-42DC-AF5D-A3EAF3AA4A5C-559-0000006E082C9D7E_zpsa1075c1d.jpg~original
19BD56CA-FDB6-4E61-907A-8AF7654E5998-559-0000006E04EF755E_zpsc5a9ab20.jpg~original
FX-R III Retrofit
Ordered FX-R kit from TRS on the Taco World GB. Unfortunely, the Guns are on back order. Hope to see them ship by the end of the week.
Products
•1x Pc: H4 MotoControl Harness: $0.00
•1x Pair: 90mm White xbaLED: $50.00
•1x Pair: 3Five D2S 5000k bulbs: $0.00
•1x Pair: Gatling Gun: $0.00
•1x Pair: 3Five LC D2S ballast: $5.00
•1x Pair: FX-R Projectors 3.0 (LHD/3in): $10.00
•1x PC: FX-R Stage 3 Kit: $315.00
•1x Honoring TW 25% gb: $-97.50
•1x Pc: Resealing Glue: $10.00
11th mod: Extended E-Brake Bracket
Cost: $0
Hours: .25
So, before I install my newly acquired LC coils, I need to extend my e-brake bracket. I've read different options on how to do this, but I happen to get lucky and come up with an easy solution.
I took one of my brake line bracket/clamps off of one of my motorycles (one that I put ss lines on). Bent it open and reemed the bolt hole open so that the stock 4Runner bracket bolt would fit. Found another bolt/nut/washer and blue loctite and there you go!
The motorcycle brake line clamp.
3416553E-65A1-4A13-AA0A-C5C274E58D6F-446-0000007CEF1822C7_zps1d0f0cf4.jpg~original
The stock set-up on the 4Runner
239F2282-3B3D-4EB4-B6AB-415D85E0EB95-446-0000007CE68DD816_zps33fa089b.jpg~original
The extended e-brake.
The nice thing is the motorcycle bracket had these little tabs that you could bend in so it didn't move!
430BE5BC-EB0D-4787-AA2D-859AD46A2EAE-446-0000007D0FD4C8E1_zpsddaedd59.jpg~original
12th Mod: Extended Rear Diff Breather Mod
Cost: > $20.00
Hours: .75
Will I was doing my e-brake extention mod. I decided to also extend my rear diff breather. This mod was prettystraight forward. I put the truck on some ramps to make easy to access everthing.
I bought about 6 feet of hose, but only ended up using about 5 feet.
Parts used.
F3051795-6966-4DE1-88DF-A0D4529804AC-446-0000007CE92A24C4_zpsc6a012a1.jpg~original
C07F1822-DF03-4214-A70B-CA2A9357BC34-446-0000007CECA26EEA_zps6ff245bb.jpg~original
Popped the two tabs that hold the fuel shield thingy, so I could run the line.
B10CAEB2-BEF0-49E0-897D-0B191553533D-446-0000007CF2474037_zps62ee0335.jpg~original
FC773037-1A72-447F-A60E-21A87983FA65-446-0000007CF4FDBC21_zps76777b7f.jpg~original
Took a knife and cut an "X right above the fuel filler.
D432FE74-FE92-4457-A311-A2E742A4D9ED-446-0000007CF7514EBA_zps2c014875.jpg~original
DDD1A1FD-C7AF-48F3-8676-ECDF4F867300-446-0000007CF9AD3DC5_zps1eec80a6.jpg~original
Fed the line through.
9DCF7569-C58B-4E63-985C-1BA3C4BE2FFD-446-0000007CFC22DF62_zpsd3cbc8cd.jpg~original
8D4DF990-8570-4DEF-A7CA-2E70B7F6DF59-446-0000007CFE7EF501_zps85fcebeb.jpg~original
8B04DC9F-D1F8-4E10-A2D7-6DC09B6CE8F1-446-0000007D02EF4909_zpsd4932f0a.jpg~original
Installed my new breather fitting with some clamps.
F5685FFE-1515-4C14-A92A-FCD8911CBE38-446-0000007D0539F24F_zps8b244d2e.jpg~original
2BFCFB76-DFEF-4549-8246-0C4497C11134-446-0000007D0A0DCCA2_zpsbc22f9da.jpg~original
4C9D8832-7963-4547-8DEF-4DD5DE4862C8-446-0000007D0D50777B_zps6458d443.jpg~original
E9E5620C-4F73-45B7-A338-EC125006DB6A-446-0000007D078B0161_zps146b1379.jpg~original
I like in all the efforts to cover your license plates with humorous images (which is funny btw) you missed one :D
That's one huge LC yard! I'd love to part me together a 40 series!
Good work btw! Looking forwards to the projectors.
Thanks, lol!
The one you think I missed isn't one of my trucks/cars, so I didn't care to cover it.
That LC yard was insane! I was like a kid in a candy store. I would have spent more time there, but I was in dress shoes and the place was like a muddy land fill!
Can't wait for my retrofit to get here! I'm going to bug TRS tomorrow to see if they have an updated eta.
Thanks, lol!
lol, ahhh.. I see it now. Yall are twinkies for sure. Happy modding!
13th Mod: Replace License Plate Bulbs w/LED
Cost: $15.00
Hours: .25
Toughest part was getting the old bolts out clean.
Thanks! Picked up the bulbs at the Philly auto show from one of the venders. Sorry, but not sure what brand they are.
Right now I have the LX450 coils in and they are much better for me than the 890s. I'll post a write-up when I have time.
goddesszilla
