• TAP is reportedly Out of Business Oct. 2022 per this thread.
RIGID Adapt E-Series Cutting-Edge Technology
The RIGID Adapt E-Series LED Light Bar features the same style and construction as RIGID’s
legendary E-Series, from the high-strength aluminum heat sink to the unbreakable polycarbonate
lens.
On the inside, however, the Adapt E-Series contains cutting-edge technology.
The Adapt E-Series takes off-road lighting performance to a whole new level with two layers of
adaptive response to your vehicle and driving conditions.
Features
  • Harness, Switch & Relay Included
  • 3 Optic Zones - Scene, Driving, Spot
  • Seamless Beam Transition
  • Slow Speed, Moderate Speed & High Speed Beam Patterns
  • 9-36 VDC
  • Two Layers of Adaptive Response
  • Active Power Management™ System - Power Capacity Sensing
  • Active View Technology™ - Internal GPS Module
  • Use In Adapt Mode Or All On
  • Limited Lifetime Warranty
  • Alloy Housing and Heatsink
  • Unbreakable Polycarbonate Lens
  • Pressure Equalizing Vent
  • Black Exposed Printed Circuit Board
  • Patented Optics
  • 50,000 Hr+ LED Lifespan
  • Off Road Use Only
Lights Come With
  • Stainless Steel Mounting Brackets
  • Hardware Kit
  • Wire Harness
  • Relay
  • Switch
  • Install Instructions
Rigid Adapt E-Series Options - Click Here
_
2001ATL
