rigid industries grille questions
Frat_4runner
i have been looking at a rigid industries grille and fog lights mount, but i have got some questions that need to be answered before i drop 700 dollars on the mods. how does it mount in the grille slot? will off brand light bars mount in where it goes if they are the according size? does anybody else offer a very similar product? how do the fog light mounts install? will any off brand LED pod fit in its place? and yes i do understand that it is a bit over priced lol
You've come to the right place. We introduced those items to the market and can get you an awesome deal on both if you like.
To answer your questions about install, you need to mod a few things to get it to fit. Check out these instructions for install, although these are for the 2013 4runner, the process is the same for the 2014+
http://www.partners-rigidindustries.com/images/20102013Toyota4RunnerLowerGrille.pdf
You can use a light bar that matches these dimensions, although if price is a concern I would check out the new Rigid Radiance series, they would bolt right in and cost 1/3rd of the standard e series. 20" is under 228 delivered from us:rockon:
The Fog light mounts from Rigid replace your entire factory fog system. There is a face plate and a mounting bracket included. You remove the Rigid Dually bracket that comes standard and attach this to the two side bolts, and then bolt the face plate to the cover of the Rigid dually. Any light with the dimensions of the dually will work, but of all the 3x3 cubes out there Rigid is by far the best.
g-80579.aspx
You can see on this similar tacoma mount how the light attaches.
BillM777
