Rim Help Anyone?? nuts want fit
SavinWillyWonka
So I got my rims it today for my build and the holes line up but there no way nuts are going in much less a socket my pattern is 6x139.7 I have spierxx spacers or whatever there called.
well the spidertrax also have the 6x5.5 lug pattern so its probably not the studs, what nuts are you using? stock? and what are the rims? aftermarket wheels sometimes require different style lug nuts.
My profile pic is of the rim and holes bc im doing this on my phone, stock want go im going have to have a new set the problem is what set of lug nuts do I need, I have the dropstar64B. Im not sseeing tunner lugs to fit a 4runner
How do u like the 20s on yours? They fit ok not rub when flexd? U have 33s?
Funny you ask... I actually just ordered some 17's with some 33 x 11.5 tires.
I like the 20's just fine, they just aren't that great for off roading. I did a lot of work to clear 33 x 12.50's but at the end of the day, that is a lot of tire for these trucks.
The reason I asked is bc i had 20s on my Tahoe but off road wasent good.I just ordered 18s. How high is your lift? Im doing off road build so figured 18s were way to go
18's are better than 20's, but I'd recommend 17's purely for the fact that tire sizes are more available as well as prices are a lot better. I've got your standard 3" lift with a 1" body lift.
You need to contact the manufacturer of the wheels to find out which ones are correct. Do not guess because if you are wrong, you risk damage to your wheels or worse, one coming off.
