rkntoy's Oil Changes and Broken Things
Anybody else see an issue?
Weekend's projects:
  • Phase 1 of security projects
  • Stronger detent spring in crawl box (pops out of low on inconsistent compression)
  • AssBurn's link install
  • Install my new (used) dual bander
Didn't get as far on day 1 as hoped as Dad decided to spend the weekend at the hospital. One more day to go.
Lookin good! I’m looking forward to seeing you try and beat them up on the Dusy in a few weeks!
Definitely not some of my best welding work. There were some really awkward spots with those weld washers.
I am telling work that I am taking more time off today - countdown time!
I don't need another project but I am getting one anyway. Already have the 37s for it.
Well it is home. And I snagged a big piece of the build for $100 - Gem Top Commercial cover from a 2014 Nissan Frontier.
Sent from my SM-G930R4 using Tapatalk
Thanks [MENTION=118730]AssBurns[/MENTION]! Love the articulation. I may bring the wrenches to shorten the lower arms a bit to center the wheel when stuffed.
Lookin good! Not sure if you adjusted them from where I had them but I think I had them set for around 1/2” or so shorter than stock links for that very reason. Also shortening the lowers helps with pinion angle as well. Time to go beat those things up!
