rkntoy's Oil Changes and Broken Things
Lookin good! Not sure if you adjusted them from where I had them but I think I had them set for around 1/2” or so shorter than stock links for that very reason. Also shortening the lowers helps with pinion angle as well. Time to go beat those things up!
I did - made them a little longer. Now I will make them a little shorter.
What the hell did you do?!
Was playing around on one of the rock piles behind the house "testing" the rear suspension...picked too aggressive of a line backing up with my steering all the way to the driver stop.
Now I get to fix and then mad dash packing will ensue.
It is out. Ended up using aluminum can to shield the needle bearings.
Sent from my SM-G930R4 using Tapatalk
It's kinda funny how where all fixing shit at the last minute. This trips gonna be a dusy. lol
I've gotten most shit packed up but I know I'm forgetting something. Any chance your bringing bailing wire? I've got plenty of zip ties and duct tape to go around but have no idea where my roll of bailing wire is.
That an OEM CV?
Thought: you could center drill out the inner shafts with a 1/16” hole. If it ever failed you could sneak a tool through it or tap it and put a bolt in.
Curiosity...is that cv oe or aftermarket?
Also, good fix!
EDIT: Dang it Mr. JZiggy!
I am trying the Napa MaxDrive CV axles out. So far, not so happy. We will see after the Dusy Ershim trip which way I go - taking 3 spares with me.
May switch back to OEM as I talked to the local parts manager and he will match internet prices for me so I don't have to ship cores around. He would not do that before so I tried plan C. Plan B was making my son use Autozone "Lifetime" cv's on his - that really didn't go well. You should have seen those ball bearing flying down the sandstone on Hell's Revenge.
I didn't have great luck with the OEM ones either - broke this one and it took out my manual hub.
A company used to make “hub fuses” for 1st gen Aisin hubs. The inner ring which the dial face moves up and down to connect the hub body to the inner splines was modified with some weak points. This ensured it would fail first. But then your hubs would be full of metal chunks so I’m not sure it was that much of a benefit...
I used to have some on one of my first gens. I thought they broke wayyyyy too early.
Tougher cv axles would be nice - can't see myself doing a straight axle from a time or $ perspective. Every once in a while I get tempted (thanks [MENTION=67615]Dirtco[/MENTION]) but then the feeling eventually passes.
charlesz
