Rock Sliders are the interchangeable across SR5s, Off Roads and TRD Pros
kfs-4runner
Rock Sliders - Would there be any difference between sliders for any sub-models of 4Runners? I found a set that says they are from a "Trail Edition Sliders" but I not sure why they would not fit an SR5. Do TRD Pro and Off-Road trim have anything specific about the frame that would result in sliders being specifically designed for a certain model?
The only thing that could be different is if you have an XREAS system or KDSS. I'm pretty sure the system that controls all of that is in the way on the side of the frame. Otherwise everything should be exactly the same
Unless it was a model year prior to 2014. The SR5s had rocker panels similar to the Limited, other than that I can’t think of why they would be different.
As others have said, the limited rockers and pre2014 face lift SR5s which used the limiteds, were different.
KDSS might be an impact on some slider mounts depending upon vendor design.
Kaliram
