Roof Rack Side/Rear Lights
mtomaro
I'm trying to pick side and rear lights for a Gobi style roof rack. Primary use will be to illuminate campsite, work area, trail during slow crawl, etc. General illumination is most important so I'm looking for a wide flood pattern and quite honestly, I don't want them too bright.
Specifically with the sides, I'm debating between a small 2x2/2x3/3x3 style led pod or a slim single row 6-10" led bar. The biggest advantage I see to the slim bar is that it can be installed with minimal protrusion from the rack itself and will likely work better with an awning should I choose to add one in the future. The pod, however, would give me the option to angle it slightly forward or backwards rather than only 90* from the vehicle.
Similar arguments could be made for the rear. The tricky part with the rear is getting them mounted high enough to minimize the dark void created by the roof/rear spoiler while also keeping a low profile and minimizing wind resistance/noise.
I've searched around but have really only found "I run this or that". I'm looking for any specific insight or advice y'all have between he two options.
I have thought about this recently too. The sides I've decided that single row is best but for the rear I'm kicking around the idea of a slim single row mounted under the spoiler. The overhang from the spoiler will block a lot of light.
Agree but I'm not sure I'm ready to take that step. I like the easy of rack mounting.
at the risk of sounding stupid... it would be cool to see a 90degree wrap-around LED bar that could be mounted to the corners of the gobi, continued with straight LED bars along the sides and back for 1 continuous halo of sorts around the vehicle....
I'm kinda looking at trying the wrap around led bar thing once my gobi comes in. Curved 40 in front then some 20s on each side. 20s will be floods and 40 combo
20s seem huge... I'm thinking 6-12" I don't know the spacing between the vertical supports but I know a 20" would have to sit outside them where as a smaller one could sit between.
I'm using Phantom Trailhawks on the top...Rigid diffused cut into the bumper...best of both worlds.
Phantom LED Off Road Lights
I also have LED's cut into the hand holds of the lift gate with a switch tucked in there as well. (so when the rack lights are blocked...you still have nice area lighting behind the truck
Yes il still working the plans. Will measure and get better idea once rack arrives. Using Heise LEDs so will have to see what sizes they have smaller than 22 and 20
delislerebecca
