007Tacoma
...it does what I need it to do, hold my ARB awning and haul my gear for extra space within my cabin. :reddance:
Got pics of how that awning is mounted???
Got pics of how that awning is mounted???![]()
Looks like this has to mount to cross bars.Before I bit the bullet and went with the PRINSU 3/4 rack. the set up I was looking at was the Rola Roof Rack (found on Ebay for less than $150) and then instead of mounting to the cross bar, I was going to cut mounts using a angle bar from home depot and u bolts.
The rola is the only rack I found that has bars running down the sides that could be used to mount. If you are not into making your own mounts, there is a company that sells mounts for the rola. Cannot remember the name of the company but they are for the 4th gen. they are called low profile mounts and they can be used on a 5th gen, may need to add a small spacer to make sure it does not touch the roof though.
Mike
I just had a Thule Canyon rack delivered yesterday. And I was planning on mounting it using the factory cross bars. I have a sun roof and shark fin antenna and the basket should work fine.
There is also a new Thule Trail XT roof basket (medium). This is pretty expensive but I think it would've worked behind the sun roof and in front of the satellite antenna (it's a little longer).
https://www.rei.com/product/103194/thule-trail-xt-cargo-basket-medium
Have a Canyon with the extension on my 02 (replaced a Yakima Load Warrier with the extension) and I really like it. It's is much better looking than the LW, it makes less noise at highway speeds and it fits perfectly.
Do you have a satellite antenna up there?
Sent from my SM-N910V using Tapatalk
Here are a couple pics of my Rocky-Road rack I did however slightly modify it for my purposes.
I had the side bars Powder Coated Black.
can you show us photos of your ride showing the roof rack from the other side without the awning? I like the low profile look of the rack, I have some friends looking into getting something similar.
Does it mount to the crossbars or directly to the rails?
Here you go. I didn't shoot it straight on sadly, so the angel is a little deceiving making the basket appear taller. But it is in-deed pretty sleek and low-pro. The big benefit, is that it fit in my garage perfectly :clap2:
