Rubbing still after BMC and 285's
I don’t have wheel spacers. What should my offset be? Unfortunately, I couldn’t go with less offset due to the loss of backspacing…uca manufacturer (Jba) recommends 4.75” or more to clear the the Uca. I considered more offset, but was under the impression that the increased radius of the turning wheels would create even more rubbing.
thats the correct impression about more radius. foolproof way : remove spring, cycle suspension with tire mounted, trim where needed. or just keep trimming until it stops rubbing.
UCA manufacturer may be screwing you a bit too, but go try and get some stock rims, swap your tires onto them, and tell us if it is better or worse ;)
alexaturner
