Rubbing with 285/70-17?
hyperduc1100
Stock SR5 wheels, Toytec 2" springs and Bilstein shocks in the rear. Stock springs and Bilstein Height adjustable front.
2.5" front, 2" rear, any issues?
More than likely Terra Grapplers or KM2's
The front will probably rub in reverse. If you move the fender liner forward you will get rid of some of the rub but, at least for me, it will come back :frisky:
For tires, check out the Yokohama Geolander AT-S as well. Just as aggressive of a look as the Terra Grapplers with less noise and a 50k warranty. I have been really happy with the 265 and 285 Geolanders on my truck.
I run the same size tires (Goodyear Duratracs) with a Overland Warehouse--Radflo lift. I experienced the same problem and resolved it with some frame trimming and cutting out the plastic wheel wells. Now that I put on a Shrockworks front bumper, more plastic trimming was needed and the problem is essentially resolved. If you change out the wheels for some different back-spacing, you supposedly can avoid having to do any trimming.
Cheers,
Greg
phisfunk
