BamaDrewski
Here it goes. I have read where it is “recommended” to run a tank full of NON-ETHANOL gas through engines at least once a month to “clean/flush” out any nasty gels/remnants of burning ethanol modified gasoline. Has anyone else heard this? Given the expense of non-ethanol in this area, I have been running the ethanol blend.
At first glance, it makes sense. So, I have filled up today with a tank of non-ethanol gas to see if there is any impact on gas mileage and if nothing else, I did so with the hope it "couldn't hurt"...
I do know (from experience) that small motors (especially 2-cycle) run like crap on gas with ethanol. I had to break down a weed eater and clean the carb after running the E-crap. Apparently, (as legend has it) the alcohol in the Ethanol is hygroscopic in nature and attracts moisture. As a result, this moisture can turn into a “gel” ……
For what it is worth, I am on my original fuel pump. I run a fuel injector cleaner through it at least once a month. My two favorites are MMO and Seafoam. If I am about to take a long drive, I always add one or the other. I also have all the original fuel injectors at 307K+ miles.
With all the info out there, it’s hard to discern what is myth or reality. That's when I turn to the real-life panel of users and experts on T4R.org. If anyone can speak to this and/or has opinions/insight, please post it up! Thanks folks!
