Run into a road block with my TRS HID kit
jstim
Here are the cliff notes on this. I have a 2015 TEP, and I ordered the 50W HID kit from TRS. I have the entire front bumper off, and am trying to get all these plugs plugged in properly, and planned on drilling the cap LAST. I figure if I have a malfunction, at least I can put it back to stock and it will be ok.
Heres my problem, I have one lug labeled OEM input, and one labeled ballast, and it seems like I am having all kinds of fitment issues.
Any input on how someone may have done this would be great thanks.
Just installed mine as well. I did not remove the bumper.
I assume your troubles are that the plugs don't seem to fit? I had similar issues. Seems like they dont, but they do. Just make sure it's lined up correctly and just give it a good push.
So I got it all figured out. I took the bumper off because I was originally going to take the whole headlight out as well as pull that silver piece off and plasti-dip it black. Ran into a few bumps in the road, but alas it is done. As soon as I figure out why I can't get my pics to come up I will put the pics from start to finish, and its the 50W kit.
I do have a wonky plug fitting on the drivers side...its loose, but it fits. Any one got any ideas to tighten it up.
This is how I did it. I am glad that I pulled the bumper off in the end because of where I ended up using a bolt up front.
The valuable lesson, test it before you put it together.
