Running board help
Part number
Reviving this old thread. I am also looking for the part number for the short bracket set. Removed the rocker panel on my 2024 LE and would like to reuse the running boards that came with it. Can't figure out the part number for the shorter brackets. I did install the current trail edition boards but they are short and look strange. Installed the old edition of the trail boards but hose are slippery when dry and very slippery when wet. At this point I figure I would give the boards that came with it a go with the shorter bracket if I can find them. Brackets are not interchangeable due to the channel spacing on the aluminum extrusion that the foot plate bolts to. Thanks for any help.
I’d probably look at aftermarket running boards with a lower step height before having the OEM brackets fabricated.
