Rusted Broken Bolts - Beware
BigMike18
Member
I was doing just regular maintenance taking stuff apart and replacing cause of old age and all 4 of the lower valve covers bolts had snapped off and this is not a problem you want to have. Ive tried everything I had at my garage, didnt work got it towed to local shop, they heated, welded, lubricated, everything to try and get those things out. Now have to raise engine to fit drill in enough to tap the threads. If you have a rusty old 200,000 miles plus 4runner I do not recommend taking this off unless dire need. My gaskets we fine and the tube seals looked great. 05 V8 220000 miles SC Vehicle
Hopefully everything works out
sometimes i look at a bolt and think the worst case scenario b4 i even touch it....occupational habit i suppose that and 12yr old truck in Canadian winters
Good luck
peacefulpiranha
