S-Tech 5th Gen Specific Switch Systems - Review/ Overview - Factory Look and Feel
ehcanadian
Hello All!
After having this S-Tech Switch System for close to a month and using it almost every day I feel comfortable sharing my review, installation and even a discount code for forum members! As you will read I was beyond impressed with the product, and personally believe this product should be in hands of more owners in which the product is tailored to; 5th Gen 4Runners. Which is why S-Tech has given me permission to offer forum members 10% OFF their purchase from www.stechswitch.com/ by entering the code: Toy10
First and foremost I want to thank S-Tech and Team Tech Offroad owner Scott for providing genuinely some of the best customer service I have received, even with a time zone difference no matter when I sent an email I received a phone call minutes later with him happy to answer any questions right there even throughout the weekend.
Lets Begin
My search for some sort of accessory and power management system was prompted by a growing section of my home that was being filled with mods I wasnt ready to install until I found an option that fit some criteria I listed below in no particular order.
1. It was aesthetically pleasing and tied into the vehicle cleanly
2. Performs as intended (the obvious)
3. Cost Value (To extend on this Im a person that needs "Justification" for why something costs a certain amount. After owning and using the "Bigger" name units in other vehicles I always felt the price didn't match what I was receiving. With some units now hitting upwards of $900 in cost with bare minimum included I wanted to seek other options
After some researching I came across the S-Tech Switch Systems and after some more research found a growing popularity among the Jeep community. The big thing that caught my attention was the 5th Gen 4Runner Specific offering which includes; a 3D printed switch housing for either of the awkward cubby spots below the head unit AND a 5th gen specific engine bay mounting bracket for either the driver or passenger side mounting. All is made in-house and there is no need to look for mounting accessories from another company or make your own. After emailing a few questions I had I quickly received a phone call from Scott and he explained everything I needed to know and more. I was sold on Scott'scustomer service alone, I ordered the minute we got off the phone and my order was shipped the next day.
My Order
The particular configuration I ordered was the Custom 6 Switch System option All for the price of $344.99 (this is without the 10% off forum discount code: Toy10)
Custom S-Tech 6 Switch System
  • Custom 4Runner Switch Housing w/ install template
  • Customization in Switch Layout, Switch type, Color and Accessory specific labeling
  • Power Control Module
  • Plug and Play wiring Harness
  • Custom powder coated Mounting bracket
  • All Mounting Hardware
  • Accessory Fuse tap
  • Install instructions
Again all for $344.99
In addition I ordered I ordered their 60 Amp Circuit Break W/ 24in Battery Extension Cable a $20 addition I think everyone will highly recommend you get to protect your vehicle.
Package Arrival and Contents!
First Impressions
I was pleasantly greeted with "Proudly Made in the USA" (Colorado Specifically) stamped and stickered inside and out of the packaging. As well as being greeted by S-Techs new 5 Year Buyer Protection Warranty before you even open the box that holds the unit and switches. After taking everything out the overall quality is incredible. Everything from the precision of the custom housing/ bracket, quality of the rocker switches, thick protection surrounding the wiring and of course the power module, All met if not exceeded the quality of other comparable units on the market that are being offered for hundreds more. In addition, their focus on the consumer is unmatched by not only providing such a bang for your buck but also by simplifying installation through clear directions and guided templates, which gives the consumer a sense of ease when installing and pride when it is all installed and working!
On top of everything else, you get the impression of the companies confidence and willing to back their products, especially since the original warranty of 3 years wasn't enough for them to receive a unit back they challenged themselves by giving purchasers a full 5 year Warranty Most manufacturers offering similar product offer 2 years at max
My Chosen Switch Layout and Custom 5th Gen Housing
Fit and Finish
First image is showing the switches installed as a whole. Second image provides a close up of how perfectly the custom housing fits inside the cubby
Installation
I will go into full installation walk through in the post below this one. But install was as simple as it could get. Between the detailed instructions and fool proof template provided the install should be a breeze. If I wasn't doing a detailed install I would have been done in closer to an hour and that is including dis and reassembly to remove the lower cubby section
The Engine bracket uses two open factory bolt points and just needs to be bolted with supplied hardware. and before you fully tighten the bracket it allows for several inches of adjustability if you wish to move it closer to the battery or more towards the cabin. Only somewhat difficult part was running the cable through the firewall which in reality is still not bad just need to be careful. As well their is plenty of wiring so you could easily install the system on the passenger side and still cleaning run the wiring around the engine bay to the firewall grommet on the driver side.
Power Module and custom bracket
In Addition if you prefer a different bracket style Power Tray Makes a Bracket specifically for the S-Tech System and 5th gen 4Runner
Brief Install Notes Cont.
Powering The System: I have the unit wired up so that switches are only powered when the key is in the ACC position and obviously when running. Unit turns entirely off when the key is in the off position, so there is no power draw. If you have a dual battery setup with some accessories that might be always powered like a fridge or camp lighting, definitely add in both the voltage meter for the status of your accessory battery and add S-Techs Low Voltage Disconnect , and the switch to toggle the back lighting on/off.
Overall Thoughts Thus Far
After a month of daily usage Ill comment up to this point as far as my experience. The system is preforming now just as it did the day I installed it. Switches haven't lost any "spring" even after the amount of times ive sat in traffic and flicked the blank switch hundreds of times out of boredom, still feels the same as when I took it out of the bubble wrap.
I did want to comment on the Dual USB Voltmeter accessory. as well I wanted to see how accurate the voltmeter is, after testing it I can safely say it is on point with its readings. On top of that the USBs have charged both an iPhone XS Max and an iPad simultaneously from 0 to 100% within an hour which is impressive when comparing to the factory USB that doesn't provide enough power to even maintain the current battery percentage.
Something to note is the unit is NOT waterproof but is water resistant and which is something I wanted to test, after running through several deep puddles and water crossings the unit never skipped a beat.
At the end of the day the real thing that matters is that the unit will do its job in powering my accessories and protecting my vehicle/ accessories from issues like a short or overheating (luckily I haven’t had to test this yet). But, thus far the unit continues to be extremely reliable to where I have no doubt every time I flip a switch whatever accessory is attached will turn on. In addition if something does happen or there is an issue have the satisfaction of your 5 year warranty while most companies have 2 years at max.
Again I have to comment and thank Scott for providing the utmost customer service and reiterate his passion and desire to put the best product forward for his customers.
If anyone has any questions please feel free to either write here or send me a pm Id be happy to help out!
Attached here is my system as well several other possibilities and configurations possible
Have to say that looks like a nice system for the money. I've been wanting a switch system but no way am I shelling out S-Pod money. I do wish the switches were more Toyota OEM looking but I know that's not feasible. Thanks for the review. Couple of questions...
1. Does he do any other switch labels, like Raptor Lights?
2. Are the switches dimmable?
My apologies on taking so long to respond I have been traveling for work!
Honestly the system exceeds the price. I did shell the money out at one point but didn't want to do it again on a SPOD. Don't get me wrong the Spod is great, even the Owner of S-Tech acknowledges this, but the S-Tech holds up too if not exceeds its competition. Even including the custom housings it was no brainier to give it a try
Ill speak to scott but I do believe he has a oem push button style in the works. In addition he does have a 6-Point touch pad option already available.
As far as the switch labels go there is a bunch of options and they are always adding more. The rocker switches are actually interchangeable with a bunch of different companies, the actuator covers can be simply be popped out and swapped without removing the unit.
There is a dimmer option available however, the led back lighting is very subtle that it doesn't cause an annoyance when driving at night. Its enough to see what button you're pressing, gives a nice little amount of light cast to the center console area as well at night.
Any other questions I'll be happy to answer!
Thanks for the response. I like the touch pad idea just wish it came in blue. May give him a call this week. Thanks again.
Hey boss, just got back from vaction so again my apologies on the late response. Just spoke to Scott at S-Tech, he does in fact have a OEM push button style switch system available and ready to go for 4Runners.
AND scott offers a low lumen switch that can be tied into the factory light dimmer switch. Scott said give him a call or email at 720-307-7263 or [email protected]
Hey guys,
Just to add onto this as an possibly mount location, here is a link to a 3D print file that will allow you to replace the sunglass holder location for the switch location. It does say spod but I am positive they use the same button placement/style mount to use this.
4Runner sPod Mount by cw360 - Thingiverse
I'm positive the creator for this file is somewhere here in this forum [emoji848]
Anyways if you dont have a 3D printer, there may be a company near by that does or even reach out here on the forum. If not hit me up, I have one near by and can get it printed and shipped to you :)
Sent from my SM-N950U using Tapatalk
Great news. I'll contact him. Thanks for the info.
Why do you think it isn't feasible? If you look at the back of the switches they're just wired in with female blades. You should be able to pull that apart and put your own switches anywhere you want with some extension wires.
This is what I plan to do eventually as I only want to use the oem switch blanks on the left side of the steering wheel. Even if that limits me to 5.
I was just saying that it make not be feasible for him to make the panels with Toyota specific switches, that's all. Seems this he is doing that now so obviously I was wrong. LOL
Just spoke to Scott at S-Tech, they are going to make the oem style push buttons live on the site tonight or tomorrow. Going to have a ton of options available
You should mention that the 10% off coupon is only valid on orders of more than $199.99. :wtf:
Yes I wrote you a response apologizing for the confusion in the last thread but it got deleted. The discount is meant to attribute full systems + accessories which begin at $199. I will Clarify when I get to my computer
Thanks. I didn’t see your response before the deletion happened.
Did you figure out if their website has the electrical specifications for the switches listed somewhere? I’m considering the mini ones that fit in the 4 switch small cubby frame. Wondering about the DC current capability.
Also, the online installation manual photos are messed up. I’m looking at them on my phone browser.
I will get the specs to you today! Ill mention to them about adding the specifications in the product listing itself to make your question easier for anyone else.
Would you mind sending me the the manual its showing up weird for you? Its uploaded as PDF which is odd that its excluding those pictures
2001ATL
