Sagging suspension on driver side rear.
Clrems77
2017 Trd Pro with an Icon stage 7 kit. Just swapped out the rear 3” overland springs for 2” springs for a better ride when not loaded down. The driver side is sagging what looks to be an extra inch or more. Anyone deal with a similar issue as this and if so what was your fix? Thanks in advance for any suggestions.
yes drivers side lean is a common problem with 4runners and is usually amplified when raising the vehicle (from what I have read).
Seeing you have coilovers in front you can adjust the adjacent (pas. front) lower preload -or- increase preload to the drivers front up to help minimize it.
I increased preload on my drivers front and now am about 1/4" diff rear, side to side. Good enough.
Absolutely common when going over 1" and it's more obvious the higher you go. I think stock the truck leans just a bit on the driver side. I had an Icon stage 5 on a previous T4R and the installer had to crank up the front driver side a lot to get it close. Still with a full tank and driver there was a lean to the truck and the front driver side was a bit harsh compared to the passenger side on DD to work.
I'm currently using Dobinsons mild lift (see sig) with a 10mm spacer in the driver rear. The truck as it sits now with a full tank is almost spot on.
Dobinsons Rear 10mm Poly Coil Spacer for 4Runner (4th/5th Gen), FJ Cruiser, Prado 120/150, Lexus GX470/460 - Dobinsons Direct
There is a thicker one as well.
Thanks guys. Ive ordered the spanner wrench to try lifting the front driver side. If still an issue ill get the insert.
Aloha \000/
Aloha \000/
Depending on how much you need to crank the driver side... it might just be a bit easier (both ride quality and look) to add the spacer in the rear.
I was disappointed with how much harsher the driver side on my truck with the Icon stage 5 and 285 KO2s were to level out the truck. That's just my personal opinion and if I would have known about the spacer option I would have done that first.
Good luck. I love this truck and nearly the decade old product we are all driving (at least in the 5th gen forum).
Did you make sure that the rear spring is seated on the perch correctly? There is a indentation where the end of the spring should seat against.
Do you have offset weight/accessories on the vehicle? Depending how soft the suspension is, offset weight can also incur a lean.
Also find out if their rear coils are made even height, or if they're side specific, as they might need to be swapped if they are.
