Saker’s Midnight Build
April 26, 2016
AUX CIRCUIT MOD
Here is the mock-up of my AUX CIRCUIT. The Pelican 1020 Box idea didn't work out as envisioned. Not quite enough space, so I scrapped that idea.
I think this will be fine as is, not as waterproof as a busman though....
Second photo is the AUX CIRCUIT Close-up installed.
Third photo is the AUX CIRCUIT completely finished and operating as designed
Where did you get the Plexi?
Viair 88p
[MENTION=103267]Saker[/MENTION]
I saw in another thread that you had purchased a VIAIR 88P compressor and were planning to install it under the hood. A few posts later, you said it was a no-go. I just ordered a VIAIR 88P with hopes of installing it under the hood. Before I spend a million hours of my life trying to get it to work, I was wondering if you could comment as to why it doesn't work...
IIRC, after looking at the mounting, it would not have been feasible.
Would have better served mounting if another model was purchased....so it rides in a carry bag in the back....
Question
Sept 26, 2016
Aluminum Oil Filter Cap
Toyota Part # 15620-31060
Is it a straight fitment for a 2016 ??
I trying to by one from a dealer but he said it's not going to fit.... whats the part number again?
OK......
This is what I purchased, took it to the dealership and asked the lead tech (he services my T4R) and asked if this would fit without issue, he confirmed it would but you just have to swap the inner filter tube to the long one that is in the plastic housing over to the new aluminum housing.
Toyota Lexus Scion Special Oil Filter Wrench Large Tool + filter cap 15620-31060
Toyota Lexus Scion Special Oil Filter Wrench Large Tool + filter cap 15620-31060 | eBay
August 22, 2017
Installed Odyssey 34R-PC1500T
Installed Plug and Play Rear Camera Override Dongle
Thanking [MENTION=129513]bjohnston115[/MENTION] again for this mod!
http://www.toyota-4runner.org/5th-gen-t4rs/214681-plug-play-rear-camera-override-dongle.html
My install went off without any issues. Rear camera still works as normal.
Depress the AOB Rear camera switch when in any gear, camera comes on.
AOB Switch dims properly just as the other switches do.
Wiring diagram
198554d1459663841-plug-play-rear-camera-override-dongle-camera-dongle-switch-diagram.png
Camera Override Dongle Installed
Indication of Override Working
AOB Switch Location and Functioning
Hi I got this too and the AoB switch as well. Havent installed it yet. I know where to put the overide in behind the nav system. But How do I wire this and make it work? Do you mind explaining to me? I know I have to connect to 12v and ground and option of dash light. but the accesory wire go right to the 2 wires on the camera harness? Do you just put the 2 together in one splice to connect to the aob switch wire?? Look forward to hear back from you, thanks!
