Saker’s Midnight Build
June 21, 2016
DDM TUNING SABER LED HIGH BEAMS 6000K
3000lm per side of LED Joy!
(see link for all photos)
http://www.toyota-4runner.org/2393282-post44.html
Holy Headlights Batman! I think I saw you testing them all of the way across the Gulf, at first I just assumed lightning.
Looks Great!
I have to say, I'm always on the look out for your awesome 4Runner every time I go to BR or even pass through on the way to NOLA. Definitely my favorite Build Thread to follow.
[MENTION=138210]Poche[/MENTION],
:thanks:
Appreciate the kind words!
April 15, 2016
Aux Electrical Circuit Mod
I decided I would try a project to have dedicated fused power all in one place via a Blue Sea 5025 6 Circuit w/ ground bus & Cooper Bussmann Resettable Circuit Breaker CB285-100, instead of individual leads running to the battery for power.
TEASER:
I have something in mind to keep it virtually water-resistant/waterproof. I’ll see if it works out.
***Will add photos as items arrive or get installed.
Below are the items I am connecting:
• 12V Circuit for Trailer Back-up Lights
• LED Light Bar
• Engine Compartment LED Light Mod
Seems like there is something else…. I’ll find out when I start unhooking connections! :D
Started fabricating my support bracket out of a piece of 3/16” plexiglass for the Aux Electrical Circuit Mod
Here is what I did. I got the bracket from Someone in Tacoma Forums. He laser cuts and presses them for whatever you need.
I have a filter wrench for the plastic housing, will it work with the aluminum housing or do I need to buy the new wrench too?
That's pretty slick and I like that wrench. Are there known issues with standard filter cap?
If you happen to drop the OEM, it may poroduce (<--OMG, what was that) produce a hairline crack that could show up at the most unforeseen time according to my Toyota Tech...other than that it's something I feel a lot better with. Maybe a feel good mod!
Should work.
If you happen to drop the OEM, it may poroduce a hairline crack that could show u at the most unforeseen time according to my Toyota Tech...other than that it's something I feel a lot better with. Maybe a feel good mod.
I can appreciate feel good mods! Thanks.
