Satoshi Grill Mod Question
Jrlimited
Junior Member
I'm thinking about doing the Satoshi grill mod to my '99 Limited T4R. I plan on just removing the middle bar of my stock grill then adding the wire mesh. Do you guys have any tips on how to remove that bar while keeping the chrome finish?
Thanks in advance
Thanks in advance
Check out my build or a thread i made about the mod if doesn't clarify then ask me and i can look into it but awnser should be on either
I could be wrong about this but from what I have noticed from looking at several of these Satoshi grill mod threads is that many of the guys who make them use the 96-98 grills. The middle bar on those year models is not flush with the outer edges of the grill, which makes it easier to hide your cuts with the mesh. I know that doesn't exactly answer your question and it doesn't mean it can't be done with your 99 grill, but its something to take in to consideration. Good Luck with your build, I'm itching to do one myself
Thanks for the info. If I do the mod I might just end up buying a 96-98 grill to make it easier as well as save my stock one.
You'll be much better off buying a 96-98 grille from partsgeek.com or Rockauto.com. They run $50-60 and are a direct fit. I've ordered 12+ from them and never had a problem.
These grilles work a lot better for the Satoshi, you can cut everything out, fiberglass and bonds everything up, and add your mesh.
I would do what this feller up here says, he has done plenty of them. ^^^ He is the one that told me how to do mine.
I just bought a 1998 grill from parts geek and it doesn't fit my 2000 4Runner... Any thoughts!?
Better post pics of that issue......
FYI, I just did my '99 grill. Only because it was already cut up from inserting my lights in it. Now with my winch controller I needed to cut it up even more. So it's kind of like a prototype. But I would do the other style grill if you can. You end up with smoother lines.
20150424_110348_zpswyzylwyj.jpg~original
Your rig is beautiful man... Thanks for the comment but I figured it out... The clips are just different shape than the holes so I had to do some trimming
I would recommend going with the older style grille. I've seen a few done with the 99 grille and it looks kinda cheap because you can't get the smooth lines you can on the earlier ones.
Nothing should have had to have been trimmed. The early style grille fit on my 01 perfectly.
It was just hard to push the pins in.. The pins on the new grill were circular and the holes on the car were scared
Ya, on some you have to shave down the pegs a bit. Its never on the same years, which is weird. I've had a couple people tell me they had to do it...one guy called freaking out about it.
It seems random, and no real pattern to which ones just slide right in and which ones need to be trimmed. Glad you got it to work.
Just fyi, I did end up doing the grill mod. Thanks for the advice, it was very helpful.
I can't remember exactly what grill I bought or the size of the holes, but it was something off eBay like this: http://m.ebay.com/itm/350271604221
I actually used nylon zip ties to get the logo on, so if you use that method the size of the holes on the grill don't matter as much.
Laredotx
