Scangauge ll
busmup808
Anybody has this product? I got it free and I’m trying to clear a ENGINE, VSC OFF, & VSC TRAC lights on my wife’s 07 Limited Sequoia. I have no SCAN display and I’ve searched the PDF on their website and no luck.
Here’s what I’m showing from initial start
Here’s what it shows when I press MORE
Here’s the version I have 4.52
If anyone of you can help me out, you are greatly appreciated. Alojah from WA. [emoji1686]
Scan gauge 2 will only read CEL codes. If definately doesn't read SRS codes. So im sure it won't read any other independent system such as ABS, TRAC, or VSV. Sorry my braddah. I may be wrong though...
I’m missing the HOME page
This is what the home page should look like according to Scangauge
in case you need further info after using what [MENTION=105773]busmup808[/MENTION] shared, you can readily google to find the URL for the manual, and then use that to go through the programming to set up your main screen. if i take mine out of the 4R and put it into my truck, then swap it back to my 4R, it gets kinda jangled for the first use or two. if you keep it plugged in to the same vehicle, i believe it should calm down and keep your settings for you.
As soon as mine connects it goes strait to my gauge screen.
The lower right button below the display is the back button. Pushing it should take you to the screen you say is missing.
I had it hooked up in my 98 4RUNNER and plugged it in my wife’s 2007 Limited Sequoia. I didn’t set it up in my truck and I did set it up in my wife’s truck. I’ll keep it in her truck to see if it starts reading it. I just plugged it in this morning
It should show the scan function once it is actually connected to the ECU. It should just take a few seconds (up to maybe 15?).
The VSC and TRAC lights may just be on because the CEL is on - fix the CEL first, then see if there are other issues.
-Charlie
H.Sikina
