jdkilroy
Member
Just wanted to give a heads up on this new(er) Scion HU. I managed to work one of these into my T4R purchase because the dealer misrepresented the sound system pretty badly. Otherwise it is a pretty spendy unit at around 1800.00 online but I'm sure it is going to start showing up cheaper before long.
Started with a bare bones non-JBL 6 speaker, single CD system as installed from factory in a 2008 V8 SR5. (turns out the radio was a refurbished unit from factory !)
This was basically an easy, plug and play swap. At this point, I am using the amp in the HU. I plugged in the existing plugs from that bare bones radio; that connected to existing speaker wiring, the steering wheel controls, antenna.
New items included the GPS antenna, the Bluetooth antenna, the XM antenna and I am still in the process of acquiring a AUX/USB set-up.
I placed the GPS and XM antennas on the roof beneath the front end roof rack covers; one on each side. The GPS connects near instantly.
I did not connect the VSS, PKB, or REV wires and the unit is behaving fine. As far as I know, there is no hack available for this unit to get around the lockout and that is what it does. The install instructions even state that you shoud cut the VSS wire and tape it off as there is no need to connect it ...?
The reason I didn't connect the PKB and REV wire is that I was not absolutely sure which they were. (There is an unbelievable amount of conflicting information on these forums)
At any rate: The new head unit installed without any modification to the dash or the HU what-so-ever. I removed the brackets from the old radio, put them on the new one and it was perfectly positioned.
I also took the opportunity to replace all the speakers: I used all Alpine; 6x9" three-ways in the front, 6.5" two-ways in the rear and midrange/tweeter combo preplaced factory tweeters in the front doors.
I was stunned to find out how CHEAP the OEM speakers were. the magnets for the 6x9's were about quater-sized in diameter and about 3/4" thick. the entire speaker unit weighed a few ounces... tops. I'm serious, they were ridiculous. To replace the speakers, I cut the originals out from the plastic housing that is mounted to the inside of the doors. I reused these housing to mount the new speakers in so once again, plug and play. No cutting of the doors. I retained the factory appearance as the door panels still provide the grilles for the new speakers.
I plan to add an amp to this system in the future which will be really "easy" using the included pigtail that provides preamp out for all speakers, subwoofer, video and back-up cam.
I will say that the system sounds really really good as it is. Since the HU is made for Scion by Alpine, it is now a completely Alpine system. Clean, tight and really adjustable.
I looks pretty much factory except for the two blue buttons on the sides but I can live with that.
The Bluetooth connects with my phone immediately when I turn the ignition on. I don't even have take it out of my pocket. A simple set of touch screen commands transferred my phone contacts to the HU so now I can just use that to make calls.
Still learning all that this unit can do and not do so I'll add to this along with more pics in a bit.
Having a lot of difficulty adding pictures to my post tonight so will try later.
Jon
Jon
