Scion xB HU
NYFINEST
Can any member advise if the Scion HU from a 04 xB would fit in my 05 4Runner?? Thanks. I believe the part# is DEH-M8037ZT Im told its a better unit with better expansion capabilities like for XM or a changer.:confused:
I'm sure someone else will confirm this for me, but all the Scion's have the same radio. This should work in your '05 . . . . IF . . . . you don't have the JBL 10 speaker system- you have to have the stock toyota radio, which it sounds like you do. I just swapped out my standard '04 radio for one from an '05 Scion tC and it sounds GREAT.
Yes, I do have the stock and not JBL radio. Thanks for the info. The consensus seems to feel that the Scion radios are better. Dont know why that is but who am i to argue with it. I'll just jump on board and swap it out as well. Thanks again.
Good luck with the install. Try to get a copy of the manual, as there are a few things you may not realize about the HU's potential. Otherwise, let me know and I will PM you with them.
Here is a great link from a fellow T4R member with good photos to help with the install:
http://www.castulucci.com/projects/carpc/oemnaviaccess/
Be sure to read the other post about Scion HUs ( I think you already did- I think I saw a post by you up there) to make sure you drill for the second antenna.
Hope this helps
PS- Are you a cop in NYC?
BTW, if you hold down the "SPP" button for a few seconds, it will display what car the Scion HU was initially installed for. When I first got mine, it had "tC," but I changed it to xB by selecting the volume up/down button. I'm no audiophile, but changing this selection gives you a different sound. I would imagine that a smaller car like a tC would require different EQ settings than an xB, but I preferred the xB setting because it seemed to spread the bass/treble.
Another nice feature is changing the welcome screen to display what you want. I think it holds up to 12 characters, but make sure you get the T1804. The T1804 is the only model that I'm aware of that allows you to change the text. You may want to check out the "Scion HU" thread, which should be able to answer any question you have: http://www.toyota-4runner.org/showthread.php?threadid=5146
One note though, if you upgrade your speakers like I did, the HU may not be able to power them. As I mentioned before, I'm no audiophile, but I decided to upgrade the speakers to Infinity References as well. Now I have to buy an amp to power them, because the HU isn't strong enough. The guy at CC stated underpowering a speaker(s) can actually damage them. Now I know.
Thanks for sharing the info. Looks like im going to go with the Scion HU and a Roady2 XM Unit. I appreciate all your help. Hopefully even with the info posted swapping out the radios wont be a huge job!!!!!:arrow:
Ksneubec.....Thanks for the helpful info. Hopefully i wont destroy the new vehicle swapping out the radios!!!!!!! To answer your question yes i am........I see you have quite the "responder package" on your 4 Runner.:awais:
NYFInest-
Be safe down there. I used to be a firefighter in Westchester County. Now I'm up in Cow Country. Be sure to check the "meet and greet" boards for info on upgoing get-togethers with other T4R.org members- check under New Jersey, those guys have their Sh*t together and are planning something in the coming weeks near Bear Mt.
Rialm
