Scored a SUPERCHARGER!!!!
rubbman
sweeeeeeeeetttt I did some swapping and scored me a BRAND NEW SUPERCHARGER WHOOOoooooo. so now the big debate do I install now or wait untill I have more parts for my runner aka headers????
rubbman said:
how do I figuer out which gen?
First gen is gray and second gen is black
First gen:
second gen:
I wouldn't wait for headers - but would wait for some fuel upgrades. The easiest is the 7th injector from URD, easy to install and tune.
Re: Re: Scored a SUPERCHARGER!!!!
has anyone actually run individual o2's to make sure that 7th injector is being distributed equally through the manifold area? i would think so w/ the super charger being down stream of it but just curious.
Re: Re: Re: Scored a SUPERCHARGER!!!!
I've always wondered that too. I would think that if equal air pressure is going into each cylinder, like it should be stock, the fuel will atomize in the air and go with it.
WoW thanks for all the response, the s/c is a second gen(black), as far as the install I am gonna do some thinking, My runner is high on miles so I wanna be prepared to deal with breakdowns, I also want to do some research as far as what else should be installed. I jumped into this project without knowing what I was getting into(there are so many upgrades I would like to do but I also have my Bronco project and $$ is tight) so any reccomendations or Ideas wold be appreciated!!
if you give me the SC i'll put it on my truck and figure out the best supporting upgrades for you! ..... lol worth a try right?
First thing i would look into is a wideband .... there are multiple brands out there, if you decide on innovate brand stuff, drop me a PM before you buy.
check out project sport runner that guy has by far the sickest runner ive ever seen and hes got a lot of info on how to do a SC on a runner the right way
WOW 1800 I really bit off a chunk I thought I could just drop in the s/c and go looks like it may sit a while!
i just installed mine about a month ago. My truck had 156k on it when i put it on. I did the timing belt/waterpump, and a few other things beforehand. I just strapped mine on, and it runs great. No pinging, or anything. If you just want to run stock boost, you should be fine to just bolt it on and go. you can do the fuel upgrades later. I would recommend putting an auxillary transmission cooler on, and modifying the valvebody if you have an automatic. I now Have 160k on mine, and no problems to date.....no check engine lights or anything. This thing pulls like a V8 now
OK cool lots of good info out there mow for another question, where is a good place to buy my trd parts?? any suggestions?
TerryNap61
