scored cylinder wall 91 3.0 4runner
blazinjames
so I bought a 4runner with 230kms that needed a headgasket. 0 compression in #6
I just pulled off the heads and the one cylinder wall is slightly scored in one spot.
I am no expert when it comes to rebuilding engines so Im looking for advice.
im guessing the only thing that would cause the scoring would be bad rings which means I need to pull the block?
will it be okay with a bit or scoring?
any suggestions or ideas would be great
Scoring doesn't always mean bad rings. Could have been a broken spark plugs in the past. How was the compression in the rest of the cylinders?
Any time someone is in doubt of the health of their engine and compression is all over the place I would suggest at a minimum honing/boring the cylinders and new rings or pistons and rings if the cylinders were bored. It's hard to say in your case though because your compression numbers could have been due to your head gasket.
I would hate to say to put new head gaskets on it and call it a day. From my point of view I would suggest pulling the engine and taking the block to a machine shop to have all cylinders honed and re-ring the pistons.
100% agree on this. If ya gotta pull the motor its time to make the decision of completely rebuilding the motor or swapping in another healthier motor
BillM777
