SCS Ray10 and Falken Wildpeak AT3 Tires are on, pic>>>
i am just telling you what i heard while riding in his truck, my bfg ko2 are way less noisier imo.
Just got the Wildpeaks installed, they are slightly more noisey than the Hankook Dynapro ATM's they are replacing. Not annoying or something I hear over the radio at all. For how aggressive they are I am completely satisfied.
Thats a good looking setup for a daily driver!
Thank you!
And regarding road noise, if you read the TacomaWorld thread linked above, the feedback about how quiet the tires are is overwhelming.
Now I know there are two different rubber compounds for P and E ratings. I wonder if that has an effect and could be a source for the differing noise reviews? As I mentioned, my P rated tires are as quiet as the highway tire I ran previously (which was very quiet).
Thank you!
I'm running E and was surprised at how quiet they are when I picked it up yesterday.
So I ended up doing all the tire clearancing this past weekend.
The front tire rub was occurring in three places:
1.) Mud flaps - This was by far the worst of the rubbing
2.) Front fender liner - I had to move it forward
3.) Lower outside bumper - I had to trim just a little off
I did not expect the mudflaps to be by far causing most of the rubbing. One thing I'm glad I did is not going larger than 265/70/17 because with this size/offset wheel, I only have a few millimeters of clearance between the tire and the control arm when the steering wheel is turned.
All is clearanced and back to normal now.
3.) They wander just a hair more on the highway compared to my Pirelli Scorpion Verde highway tires (granted those were 20" wheels with a much shorter 50 series sidewall, so it's not exactly apples to apples comparison). I'll probably get used to this after a few days but I am having to correct slightly more than I had to do previously. Not a big deal.
As a follow-up to this, I checked the tire pressure and noticed that the America Tire only inflated to 32psi. I raised the pressure to 36-37psi, and that wander feeling I described above is gone.
I'm wondering what mods you needed to get those to fit? That's over a 33" tall tire!
Yeah it's a huge tire and I love it! So I've got 1.25" spacers to clear the stock UCA, a lift with Bilstein 5100's all around with OME 885 in the front and FJ springs in the rear. Moved the fender liner forward, removed the front mudflaps and did some slight chopping of the bumper.
Just got the OME 885's installed yesterday, will try and take some pics today! Hard to say lift amount.. I'd guess 2-3 inches. Will take some measurements later.
Interesting.
From what I understand, the OME 885's will net about 2.5-3.0" of lift. That's comparable to the Daystar 2.5, which netted me just over 3" of front lift.
With the 265/70/17 Falken AT3W tires, I had to do quite a bit of work to get the wheels to clear up front - Cut front bumper, move fender liner 1" forward, and trim the front mudflaps. Granted I have an aggressive -10mm offset on my 17x8.5 wheels, but it's comparable to stock wheels with a 1.25" spacer in terms of where the wheels sits relative to the fender.
Given how close my wheels come to the body, I'm surprised that you didn't have to do the body mount chop with that tall of a tire and only the modest lift.
Eager to see pics when ready
I also installed the 885 springs last week, I'm pretty close to 3", and that's with a steel bumper
I had the 884's on my V8 before the bumper and got about 2.5" or 2.75"
I just got these in 285s, still need to do more trimming
youngrk
