Sea Foam
NateDawg
I put in a can of the Sea Foam cleaner. (cleans spark plugs and all that crap.) Half a tank later, I feel more power, and better accelaration. Just wanted to give it my thunmbs up. Try it. Best cleaner outer Ive ever used.
Good stuff , Ive used it in other thing , not the 4R yet . I only have 25k on it . Ahhhhh , maybe a can might due some good.
I was thinking about using it on mine, but Im not sure on where it goes or how to do it. Someone know how on a 4th gen, maybe some oppinons on it?
Goes in the fuel tank.
prefered method is to pour it in through the throttle body while running...i have done it to the 4runner. didnt notice much of a difference since i generally use Redline or Chevron fuel system cleaners so most of my parts are pretty damn clean as is...
for those with over 50K miles you can probably expect to feel a smoother idle and a marginal increase in power. I have used it also in other vehicles with a noticable improvement.
So basically pull off the intake tube that attaches to the front of the engine while its running and pour it in there?
I have 88000 miles on mine will it make a significant difference?
Where do I buy some? and how much do I need?
I took a spout and put it in my fuel tank. Got it at advanced auto. get it about 120 miles, then you can tell a good difference.
you will need to pull the intake off only slightly...anymore than that and the maf will sense too little vaccum and stall the truck out...i used a funnel and poured it down there
i would expect you to see some kind of improvment....i used one full can.
