Seat Heater Install
Bump for OP and other heated seat retrofits.
It's been awhile since this tread was updated so to those of you who have done this mod, does anyone now wish they had more adjustablity than the aftermarket ones allow? Has anyone done this mod with factory switches? Anyone order the complete OEM setup and retrofit?
I looked over the 2010 factory manual, :thanks: nashman69g, but I can't tell from the diagrams what I'll find on our 2012 SR5. I am wondering if the OEM setup would include wiring to the fuse box or an existing connector. I am going to get current printouts from the parts department but if anyone has any input it would be great.
Also, to the OP and others who have done this, how are the seats holding up? Any signs of premature wear, like on the edge of the heated mat from sliding in and out? Have you noticed any seat material repositioning after reinstalling the factory hog rings? Any thoughts after the fact?
Has anyone done the rear seats? Did you tie into the same power circuit?
Has anyone measured the actual amp draw on the heater elements? Anyone have trouble blowing fuses?
I'm pretty much sold on adding the front heated seats and considering adding them to the back when I upgrade the head unit, speakers, reverse camera, and add some sound deadening. I realize that my questions are borderline overkill and I'll deal with whatever I find but I'm trying to be prepared and only disassemble/reassemble in one weekend.
Thanks to everyone,
MOJoWales
I'm picking up my 2012 Trail Friday and was looking at adding heated seats to both the front and the back. I know I could probably track down some OEM switches for the front but what do you think could be done for the back? I like adding things that look like they're suppose to be there. :nerd:
Thanks to everyone,
MOJoWales
The factory switches have been used before but it wasn't easy as you need the wiring harnesses and sub controllers too and a pretty good grasp of wiring and electronics....not me:eek:...............Thank wvanstone! http://www.toyota-4runner.org/5th-g...ork-toyota-factory-switches-2.html#post839391
I was also considering going the factory switch and control module route but in the end it seems more straightforward to go with an aftermarket that has decent reviews. You can pick up kits with carbon fiber heat elements, switches, and full harnesses with factory-ish switches for the cost of two factory switches on feebay.
2 Seats Heated Seat Seat Heater Fit Toyota Prado Corolla RAV4 Reiz | eBay
This will probably be the route I take. BTW, these appear to be the same kits (except with the rocker switches) that dealers are charging $500 for.
I promise, I searched the site before posting.
BUT, I ended up finding the above linked posts about using the factory switches going through another forum.
Here's another good read on the subject. Wiring Guru's - Stock Heated Seat Switch - Toyota FJ Cruiser Forum
Hats off to those who've done the R&D.
Rather than building an one-off custom control unit with the stock switches I'm leaning towards the ebay switches/heater combo. Although the lighting colors leave something to be desired it still achieves a near stock appearance and functionality.
I'm going to do some more investigating on the rears. One proposed idea is to take one seat heater and use the shorter part on the passenger side bottom, the longer side on the drivers side bottom. First have to make sure they disassemble like the fronts.
The average reported draw is 7.5 amps @ maximum output per heater. People have posted about running two heaters off one 10 amp fused connection and doing fine, but I would suggest making sure you have sufficient fuse protection and wire accordingly. Blown fuses are a pain. Shorts/melting/fire is worse.
Thanks for the follow up guys. Great forum.
MOJoWales
Good luck and keep us posted.
The switch color irked me a bit as well. It's possible that the harness from the ebay kit could work with OEM switches, but you'd have to get both in hand to find out for sure. The seller did tell me they use a different harness for those switches. Also, I noticed this the other day, our backlighting and indicators are mostly orange with a few greens in there too. Perhaps the combination would not look too out of place after-all. I plan to give it a go eventually, I just haven't clicked the button yet. I keep bouncing back and forth between the switch options.
I'm probably going to go the ebay route from above. But it looks like it will be over a month before I assemble all the gear I'm updating the new 4runner with, have an entire weekend to wrap it up, and shop space to work with. I won't be able to post up observations until then. I'm still uncertain about doing the rear seat but I'll post up if I find a roadblock or any great solutions.
MOJoWales
Picking up some 4Runner bits and pieces tonight and the amazon version is in the cart. I won't be installing until January so I'll be following everyone's progress with these.
Big thumbs up.
Help a Canadian brother out
Hey just curious if any of you gentlemen would be willing to purchase one of these amazon sets for me and ship it up to me. I can PayPal you. The shipper won't ship to Canada.
Going the factory parts route I think. Thanks for the offers to help gents.
Kyle
I haven't had any issues with my heaters since I installed them. I use them all the time and I have never noticed them moving or any seat cover shifting since the install. That kit looks really nice and would have loved to have the factory switch look instead of the round ones but till mine fails I am happy with what I got.
Good luck to all of you guys installing heaters, it really was a pretty easy install.
About to start on this mod... Big thanks to the OP for answering a few questions I had and laying out some instructions for this. Wish me luck. -Bandit
the Kit just arrived in the mail, it looks good, I will post pics shortly, the buttons appear to be oem toyota. No instructions included, there are red, black, green and yellow wires, I guess I will have to figure out what goes where.
if anyone in the MD with a garage is thinking about this mod, and has a garage they are willing to allow me to use, I would gladly help them install theirs.
I am in Laurel.
