sockeyesalmon
Member
i just purchase a kit from slyfox75
I just had this issue pop up on my 2005 4Runner Lmtd with 102,000 on the engine. I've got Slyfox's kit on the way, but everyone needs to make sure to file a complaint with the NHTSA. The fact that Toyota is well aware of the defect, knows the likelihood of failure and going into limp mode, and issued a recall for other models is a little too much to stomach. Even if you've used a kit to bypass the issue, a complaint takes just a couple minutes to file online.
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
Hi,
I'm new to the forum, I saw this in a search. I have a 2007 4Runner with the 4.7l V8 check engine light, VSC trac, and Slip lights on. No sounds from engine or limp motor. These came on my highlander and i cleaned the oxygen sensors, I tried that with the 4Runner and it worked for a month but now they are back on. The codes I get are P1442, P1445, and P2441
I'll try to upload a pic.
What do I need to do to get the CEL lights out?
Those codes pertain to the AIS. Air Induction System. If you are mechanicly inclined it’s not that hard of a job at all. You can buy all the OEM parts on Amazon that you will need.
I have done several Sequoias over the last month for my customers. What I am finding is the plastic fins in the air pump are chipping off in small pieces. The little pieces then get into the AIS valves and causes them to get stuck in the open position. Hence the CEL coming on.
Thank you. I looked over the components and i'm positive i can figure it out and repair it, but i bought the bypass kit in hopes of an easier less time consuming fix. The power driver seat on this car needs attention too, It decided to fail in the reclined position. Whoever owned it before me spliced and rigged the wiring and i'm lost right now on that fix.
Let me know if you need any help or wiring diagram advice.
I'm at a roadblock with this seat! The recline is not functioning, the power forward /back and up/down works as does the lumbar support. I have retraced the exposed wires in every imaginal scenerio and nothing works. I did get the seat belt light to go on when seatbelt is fastened (backwards) other than that nothing works. I have a feeling the pigtail that is hanging maybe the key to the exposed wiring??? I have attached a few pic's maybe someone with experience can tell. I have found some used seats not sure if should just replace it. (2007 sport edition 4.7L) cloth/black.
https://notpunting.imgur.com/all/
Slyfox, super awesome. i had the codes come up and emailed him. Sent him the funds and bam it was at my door in no time. The instructions are clear, ran into some issues with my 4runner, other things going on. Slyfox even tried helping me though them as well. Awesome guy!
Has anyone had p2445 come on AFTER installing the slyfox kit?
This has happened twice in the last 2 months, both time taking an exit off the highway the truck goes in limp mode, park and check its p2445.
@darkgun......do you have blockoff plates installed?
We have YEARS of running these bypasses with no reported issues like this.
The user above does not have plates. Curious if you put yours on.
I drive the same route 6 days a week, it only happened twice since temps have dropped below 30. (both times it was below 30 outside.)So what confuses me is the fact the bypass(Cant speak for Hewitt) only functions for a couple secs at startup......AND has nothing to do with the pressure sensors for the exhaust gas. There might be a glitch......but it should be a glitch regardless if bypass is installed or not. Seems to me like the issue is with the pressure sensors "freaking out" at random and sending crap data to the ECU which responds accordingly by putting you in limp mode.
The [MENTION=175406]itsnotjon[/MENTION] things sounds as if your are at decent speed......then let off gas as you exit to the off ramp....thus backpressure is high.....and could be leaking by a partially closed valve(my speculation given the data).
