Self-recovery w/ MaxTrax & open diffs advice please?
jjdbike
Hi folks
Can those w/ experience please share some advice, helpful hints, expereinces and things to avoid doing when using MaxTrax to self-recover in soft sand for an SR5 w/ open differentials?
I’m only buying one set as I don’t have the budget to spend $600 on two sets.
These look like a good option for a lone vehicle w/ out a winch that’s stuck in soft sand or even deep snow or mud.
Thanks!
JD
JD-
I have only used my recovery boards (granted, they're TRED brand) in the snow. I used them on both my 4Runner (rear wheels) and a Subaru Outback (rear wheels as well).
On the 4Runner it was too easy... Simply scooped some snow out from behind the tire, and placed the boards as far under the tread of the tire as I could. I put it in 4lo and back out as if I had never been stuck.
The next time I made sure to get myself good and buried... Again, scooped some snow out from behind the tires and placed the boards as far under the tread as I could. However, this time I also dug a little ramp behind the front tires as I had buried my 33" tires so far that I was resting on my skid plates. Put it in 4lo, and backed out as if I had never been stuck.
The Subaru was a little more tricky. They had buried themselves to the point that their tires were not even touching the ground anymore. For this one I used their bottle jack and lifted the rear tires (one at a time) far enough off the ground to get some sticks underneath, then placed the board on top of the sticks, and lowered it down. Once both rear tires had the sticks/board under them, myself and another passenger pressed down on the hood of the car while the driver backed out. In this situation they DID spin their tires a little bit, but not enough to melt the traction "nubs" on the boards.
I was (and more importantly, my wife was) immediately sold on these things. Wish I would have had them when I was stuck in the dunes a couple years back.
The biggest thing, I think, is to avoid spinning your tires. If you're not getting traction on the boards, let some air out of your tires. If you're STILL not getting traction, lift the tire up and add some material (sticks, rocks, sand) under the boards.
Great thank you Wilson. I appreciate you sharing real life experiences. One question I have is how does one decide which tires to put the boards / trax / treads under?
JD
JD-
This is really good to hear. I've got a set of the new Treds and recently installed my winch. This has got me wondering if I really need a locker and if it would be worth all the effort to swap it. Also have TRAC on my 01 so that helps some too.
JD
Put them under both of the tires on the same axle. If you put one in the front and one in the back you could still just spin one tire on each axle since you're open/open. At least with them both on the same axle one of you wheels will be driving instead of just spinning.
The biggest thing to remember with any of the polymer recovery boards is NO WHEEL SPIN!
I love my MaxTraxx and played with them when I was in the snow after researching how to use them so I can get some practical experience. I was doing well until I had managed to get the 4Runner very stuck (high centered on a pack of snow, snow drift in the front and rear, and the tires had made a small ice patch under them trying to rock it out. I had to shovel a ton of snow to get the MaxTraxx securely shoved against the tires (or so I had thought) and I was so tired from physically digging I was heavy on the pedal causing the wheel to break loose and spoon that's why about 6 of my nubs are prematurely worn about half down.
The ramps are designed to be soft to aid grip and prevent damaging tires, so wheel spin will ruin them fast if you're not careful. Always make sure they are shoved as tight against the tire as you can get them and to go slow and stop/reposition the boards if the tires keep breaking loose.
Otherwise these things are great tools to have in your recovery kit and I am thinking about picking up 2 more to have 4 total! :)
Thanks for sharing your experience.
Very helpful.
Sometimes it’s difficult to not spin.
JD
TheWhite4Runner11
