Patience is a virtue -- you can't expect to have an answer in two hours. And if you had used the search function, you would have found this: http://www.toyota-4runner.org/showthread.php?threadid=16021&highlight=serpentinejsm said:Has nobody changed their own serpentine belt?
mike508 said:In case you missed it in the link referenced above, the V6 does not have a serpentine belt, it has a timing chain that generally does not need replacement.
Atlanta_man said:mike508 you might want to double check that
serpentine not cam, maybe I read it (and the links) wrong... sorry if I did
jsm said:So, the tensioner pulley...what do all use to take off the tension?
