shavings/sludge in differential fluid!
NJI
Changed my differential fluid and turned out it was black with sludge and metal shavings. I don't think it has ever been changed and my 4Runner just broke 250,000 miles. Should I change it again soon, do Auto-RX treatment, etc?
There are always some metal shavings on the magnetic drain plug, and gear oil is pretty thick compared to engine oil.
I would just change it with new gear oil, and go from there. And clean off the magnet on the drain plug before you re-install it.
It may have been changed before, if you aren't the original owner.
My best advice is, don't worry about things until you know there is a problem.
The prick at the service shop showed me the plugged and acted like it was the worst thing he'd ever saw. I thought i was beating on my truck and the rear-diff was going to go out or something! He even said, "looks like it has sludge". But now that I think about it it was just thicker.
The service monkeys have notin better to do then act like morons and make you think your truck is dieing if you don't constantly change and replace everything they recommend:)
brendaglores
