shawnathan9
Hello fellow T4R lurkers and regulars.
I decided to post a build thread so I can keep a log of what I have repaired, modified, installed, and the results so others can use it should they like what they see as well as provide any feedback for what I've done to the Runner.
Now I've been a 4runner (3rd gen) owner for years and really kept things stock for the most part. I sold my last 3rd gen two years ago and had been driving a Lexus since then. Just recently, I had already been posting into the "What did you do to your 3rd gen today" and I'll transfer those posts onto this thread in due time.
Recently, I had the itch and jumped on Craigslist and found a local seller offering a 1996 Limited with some minor mods, high mileage, for a reasonable price.
From my initial inspection, I noticed that the UBJ was torn and I believe the previous owner didn't know how to turn a wrench and wanted to sell it instead of paying for costly repairs from a mechanic.
The paint was in immaculate condition as was the interior and trim. The lower valance was taped up but that's easily replaceable. There was a Sony sterero installed that sounded really good. It had a cheap aftermarket roof basket and some Vision 16" RIMS with new Yokohama Geolanders. Front and rear 3" spacer lifts from an unknown company. It ran smooth, shifted fine, but had some loose/rough steering and suspension. The previous owners had over 14yrs of service records. I was convinced that this is a good buy.
I was sold; I purchased it minutes before I had to run to work. With all the paper work in hand, I parked my Lexus on the curb and drove it away:
<a href="https://ibb.co/XjKW7Vg"><img src="https://i.ibb.co/0m6nCQS/20201130-172608-Copy.jpg" alt="20201130-172608-Copy" border="0"></a>
<a href="https://ibb.co/5nLTG42"><img src="https://i.ibb.co/ZYxdGXN/20201130-172555.jpg" alt="20201130-172555" border="0"></a>
<a href="https://ibb.co/CB6SPyC"><img src="https://i.ibb.co/Tc1NWGj/20201130-172743.jpg" alt="20201130-172743" border="0"></a>
Installed/reparied/modified:
7/1/22:
- Depo clear corners and front signal lights
- Toytec differential drop kit
- Bilstein 5100 & OME 880/906
- Replaced front and rear end links w/ Moog K80380 Stabilizer Bar Links for a 2nd gen
- Replaced OEM UBJs @298k
- Replaced OEM LBJs @298k
- Replaced front bumper lower valance
- NGK spark plug wires/ OEM spark plugs @299k
- Auto Meter 15411 Gauge w/ MaxTow Double Vision 260 F Transmission Temperature Gauge Kit
- B&M 70264 Transmission cooler
- Flushed transmission fluid, differential and transfer case @299k
- Replaced OEM radiator @299k
- New OEM radiator cap @299k
- Flushed coolant and replaced with Toyota Red @299k
- ScanGauge - SG2 II Ultra Compact 3-in-1
- Replaced/installed LED interior lighting & rear license plate
- BOSS Audio Systems Elite BE7ACP
- NATIKA Backup camera
- Flowmaster 50 Series Delta Flow
- Rear differential breather mod
- Sound dampening mats in rear cargo
- Fuel filter replaced @299k
- Satoshi grille mod using 2nd gen Toyota emblem
- TBU w/ 231m OEM, OEM rotors, OEM brake pads and shims; Stainless steel brake lines
- SPC UCA @300k
- Whiteline LCA bushings @300k
- 1/4" driver side suspension spacer to level things out
- Big 3 mod
- 2014 OEM 17" rims w/ 285/70/r17 BF Goodrich K02
- Installed rock lights
- BAMF Rock Sliders
- Eimkeith PCK
7/1/22:
