Shift solenoid code
poikilotrm
Hi guys.
I have a 2001 4Runner, 2WD, SR5 with a V6. It has 200,000 miles on it. I had some idiot lights pop up, and the code says it is the shifter solenoid. Should I try to fix that, or is a tranny pretty much ready for replacement at 200K?
Thanks.
Mine popped that code once about a year ago, seemed random cuz the tranny worked just fine, so i cleared it and it hasn't returned.
How does your tranny feel to you, shift on schedule and firmly? Drain/fill tranny fluid? That helps a lot of folks. :cowboy:
Hi guys.
Thanks.
Don't scrap the whole tranny! Shift and lockup solenoids go bad, you can replace them for whole hell of a lot less than a new tranny. If you decide to replace the solenoids, buy the kit on Amazon then either pay a mechanic to install them or just drop the tranny pan, pull the filter off and you will see the three solenoids. Unplug and replace them put it back together and replace fluid.
I did all three of mine on a 97 with 380,000 miles on it. That was like 15,000 miles ago and my transmission runs great.
Don't scrap the whole tranny! Shift and lockup solenoids go bad, you can replace them for whole hell of a lot less than a new tranny. If you decide to replace the solenoids, buy the kit on Amazon then either pay a mechanic to install them or just drop the tranny pan, pull the valve body off and you will see the three solenoids. Unplug and replace them put it back together and replace fluid.
Can you provide links to the ones on Amazon?
Also, the 01-02 transmissions are not as stout as the older ones.
Mine gave shift solenoid E codes when my torque converter went out. The trans slipped like crazy and sounded like it was full of marbles. If yours sounds normal, give replacing the solenoids a try like [MENTION=115590]StreetCreeper[/MENTION] suggested
It's been a while and I can't remember the exact code, but my '97 gave a solenoid related code once. Whatever the code was, when the guy at the shop pulled it it told us exactly which solenoid was bad. I got a replacement from the dealer and replaced only that solenoid. Probably put another 75,000 on the truck after that before I sold it recently, never gave any more problems.
Of course that one solenoid from Toyota cost more than the whole kit from Amazon.
Also if you're dropping the pan might as well do the filter while your in there.
It wasn't difficult to do at all really. Just drove it on some ramps to give me working room. There are write ups you can find on it.
Mine had noticeable symptoms too though. It wouldn't down shift out of drive. So i would have to manually shift into first and second gear when taking off from a stop. It did it intermittently until it got bad enough that I needed to fix it.
It works OK, but it has developed a whine in the past few weeks. I depend on that truck too much to hope, so I will be doing the filter and all three solenoids on Monday. Better safe than very sorry.
When you drop the pan, check and clean the magnets located inside the pan. If you see big slivers of metal or other things beside a little bit of metallic sludge, you may have bigger issues than malfunctioning solenoid(s).
Here is a pic of mine. It had about 380k on the tranny at the time and I was the first person to ever drop the pan. You can see the black metallic sludge on the magnets, but nothing big.
Rather than spending the money on Amazon you should contact someone in the classified section. You can usually get some good OEM ones for about $50 each. I'd rather go OEM than some aftermarket ones.
My '02 Tacoma gave the shift solenoid E code. I replaced it and about 1k miles later it died a horrible sounding death. When I had dropped the pan to replace the solenoid there were no obvious metal chunks or anything. After it died the fluid looked like someone dumped glitter in it. I would say replace the solenoid, but start saving money now incase that doesn't work. I ended up getting a tranny from a wrecker for about $1300 shipped. You can get one from Camelback for less than $1700 with a $1000 core.
What emperical data do we have to support this statement?
I don't have any empirical data.
Any details on as to why that is the case? I'm not disputing it, since I hear of those years failing most often.
When you are well connected with people that fix Toyotas all the time you hear about stuff like this. I have a friend that owns a junkyard, body shop, and mechanic shop. About 90% of what he does is Toyotas. He told me that the 01-04 Taco and 01-02 4Runner autos for some reason have more issues than the older ones. He told me that the typical life is about 200,000 miles. He has a ton of the older ones from totaled out trucks, and they are all good. He rarely sells the 96-00' auto trannys.
Sorry but I gotta say that's a load of bull crap on info about the 01-02 transmissions. They didn't only come and tacos and 4r, but other vehicles as well.
Anecdotal evidence here, but our '02 4R transmission failed at about 155k miles. Had a toyota reman put in. About 5 months later, that one failed too (under warranty thankfully). Had another toyota reman put in. So far so good on the replacement, almost 30k on it.
The A340X was offered in many cars, but that doesn't mean they are identical. There's differences for every application and year. I realize that there is no explanation yet, but I do notice that 01-02 transmissions fail more often than the 96-00.
I understand that they came on other vehicles as well. A Higher rate of failure doesn't equal a relatively high rate of failure, those are different statements. It's not like the 01-02 trannys are crap, they just have a slightly higher rate of failure especially at higher mileage.
Ohhhhh...I'm not liking this thread at all. I'm hoping to keep mine around a little longer. :(
Yeah, I just changed my transmission strainer and performed a drain and fill. After that, my tranny once in a great while will not want to downshift. No CEL yet, no pending codes, fluid level is perfect and the same fluid I have always put in. I had the fluid analyzed at Blackstone, and they said it showed no issues, and that my tranny is wearing slower than usual. That's when I talked to my buddy to see if he had a tranny laying around just in case. He did, but it had like 160k on it. He also told me that when you change the fluid, it can make the symptoms worse. He told me that the newer 3rd Gens have a little Higher rate of having issues. Same with the Taco 01-04.
Im just going to drive it until it completely fails, then buy a reman from Toyota and throw it in or convert to a manual tranny.
AndiGarage
