I know your not supose to shift from 2wd to 4wd over 50mph, my brother was driving my truck and shifted it from 2wd to 4wd at around 60mph or so. What kind of damage can that cause?
Sounds like we're about to find out.
I've switched mine at lower speeds but have always had to have it in neutral to do so. Did he switch it to neutral first?
That's exactly what it was " let's slap this baby in 4x4 mode while driving over 50mph on dry pavement" but it was on a straight road no turns, and it was only for about a minute or so.
Your truck is fine.I know your not supose to shift from 2wd to 4wd over 50mph, my brother was driving my truck and shifted it from 2wd to 4wd at around 60mph or so. What kind of damage can that cause?
If you're talking about shifting from 4H to 4L then yes the transmission should be in neutral and you should be stopped. You will also pass through the neutral position on the transfer case shift lever (if you have one). If you're talking about 2H to 4H then it doesn't matter what gear the transmission is in or whether you're moving or stopped.Sounds like we're about to find out.
I think you're right about the electronics in the system protecting itself from undue strain. I seem to remember trying to shift into 4H while going faster than 50mph and only seeing the little green 4WD light blink until I dropped back under 50mph at which point it went solid. I think the ADD might protect itself and not lock above 50mph (possibly the same thing with the dial controlled transfer?) but the lever actuated transfer case has no way to do since it's a direct connection.It's fine, nothing to worry about. I would not do it on a regular basis... But I think the 4wd control module protects itself anyway... If you have the push botton... it is in full control.
And there is no issue going over 50.. in 4h. Just shifting from 2h to 4h (you should not be spinning the drive-shaft very fast), It's hard on the Tcase to take the front drive-shaft from 0 to a high rpm.
At some speed it will beep and not engage the front diff disconnect, but the transfer case output (front drive shaft) will engage seamlessly at about any speed.
I engage at any speed in my lever actuated trail edition. Did or do any of you own older 4x4s? Not much different. If you've done this in an older one with the hubs unlocked - trust me - you wont be engaging the front output shaft at significantly varying speed from the rear shaft. - by that I mean if the front drive shaft isn't rotating, it's like trying to shift a manual without the clutch at the wrong rpm. It simply won't go.
On my lever actuated transfer case (trail edition) - it will engage the front output at any speed. I did this on tuesday morning on my way to work at about 65mph. At some speed it will beep and not engage the front diff disconnect, but the transfer case output (front drive shaft) will engage seamlessly at about any speed. And it shouldn't hurt anything so long as you don't feel a grinding of gears and it slides easily into engagement. That means your gears are already spinning at a synchronized rate.
What this also tells us is that the front shaft - at least in mine - is always spinning at or near synchronized speed. So the disconnect idea isn't really disconnecting much in the front differential.
Anyway I shift the transfer case between 2h and 4h at will whenever I want to engage the front axle. If you're going faster than Mr. T wants, it'll tell you to slow down a bit. Otherwise its not meaningfully different from shifting between 4th and 5th gear at speed. It's just shifting synchronized gears together. No big deal.
What the heck is a front diff disconnect?
Please explain that one to me....
