Shocks... yet another question
ljshein
My 99 4x4 has 62K miles on it now and not that I'm having any real problems with the shocks but I was thinking of something a little stiffer on the rear.
I frequently tow a 2000 pound boat during the summer months and I've noticed the tail end sitting down a bit more than I would expect. I don't do any off roading, unless the boat launch ramp counts :-)
My initial thought was Bilstein but I want to keep the softer OEM ride. I see Monroe makes a Sensa-Trac and even a Load Adjusting variation of the Sensa-Trac.
Does anyone else have any experience in this area and can make a recommendation?
Jeff
not sure if this is ideal for your situation, but i think it is. certainly not ideal for off road, but......
performance products sells the air bag suspension (spring kits) for relatively cheap money. you can also get a regulator that auto-inflate/deflates for you. check it out. may be what you want.
bflooks,
Good thought but I think the air suspension might be overkill. The tounge weight of the trailer is under 200 pounds.
I'd just like to see the ride level out a bit and If anyone has had similar experience with shock replacement I'd love to hear what worked and what didn't.
i run the hd billies. stiffer than stock though. many people also like the ome's. no experience with them, but many people over on 4x4wire and yotatech like them.
97RUNNERltd said:
Anyone have the KYB monomax HD shocks? Just wanting to know some info about the ride with them.
I've been running them for over a year now. I installed them front and rear, along with moog dual rate rear springs, a crank on the tor bars and poly bushings every where.
It runns way tighter in the corners, sits a bit higher, a bit rougher but not too bad, the back end sits normal to the front now, and lite towing the whole thing feels great.
I like the KYB mono max.
tuṣṭāva
