Show us your 5th Gen KDSS lifted!
What suspension did you chose for your lifted KDSS rig?
  • Icon
    Votes: 31 12.8%
  • Billstein
    Votes: 78 32.1%
  • Fox
    Votes: 18 7.4%
  • King
    Votes: 35 14.4%
  • Radflo
    Votes: 4 1.6%
  • Toytec
    Votes: 29 11.9%
  • OME
    Votes: 20 8.2%
  • Other--what is it?
    Votes: 28 11.5%
  • Total voters
    243
kings........
I have a KDSS lean but it doesnt bother me at all, nobody will notice it except you. It's like the pimple on your forehead......if you point it out, then the whole world will be staring at it.
No real noticeable lean. Did throw a 10mm OME spacer in on the passenger rear during the install, have not done the KDSS equalization *♂️
'17 ORP KDSS
Toytec Boss 3" lift
SPC UCA
SCS Ray 10
BFG AT KO2 285/70/17
Spidertrax Spacers
Kdss experts... when installing a lift I have read to strap the piston in the kdss system. What about disconnecting the battery? Would this lack of power to the system keep the kdss ram from operating?
I heard putting in 4 low will disengage kdss and help with lift installation.
Someone with better kdss experience would have to confirm.
KDSS is completely independent of everything else other than the speed you are driving. Below 12 mph, more articulation, above less. So no, putting it in 4 low will have no effect on a lift installation. Best thing to do is have a shop do it that has experience with KDSS.
2.5” Bilsteins 5100 with Wheelers T1-T13 springs, JBA UCA and 1/4” spacer up front driver side for lean. Adding 285 Wildpeaks tomorrow, removed front mud flaps and fender liner mod (zero rubbing on 275 KO2s).
'18 TRD ORP
Kings w/adjusters, 650 springs in front, Dobinson C59-723 springs out back,
Total Chaos UCAs, Cooper ST Maxx LT255/80/17 tires. Truck is lifted 2.5" in front and 1.5" in the rear.
King extended travel w/ adjusters, 2" Icon rear springs, 650lb coilover springs, a little over an inch of preload threads showing with slightly more on the passenger side, Icon delta joint UCA's, 285 tires.
Front rides a bit high especially when the truck is loaded up, but I have a lo-pro bumper waiting to go on and then I'll readjust as needed.
You definitely have some negative rake going on, but it’s not that bad looking. I think once you add some weight like you said, you will be good to go!
2018 W/KDSS ADS coil overs and rear shocks , Total Chaos UCA, 285/70/17 Nitto Ridge Grapplers.
2016 Trail with KDSS. Extended travel Radflo 2.5 shocks front and rear. 600 lbs coils up front and SAW coils in the rear. Dirt King UCAs. 285/70/17 BFG KO2. 2.5 inch front and 2 inch rear lift
Looks killer...i think you sit perfect, if darn near level :rockon:
Bilstein 5100/OME Springs
Method 310 Con 6 with 285/70/17 KO2’s
Stock UCA’s but the alignment shop was able to get it pretty close.
'18 TRD ORP
I have Kings on order with 550 front -- I have aluminum skids, steel sliders. How do the 650 springs up front ride?
It's firm but not stiff. I have adjusters so that helps fine tune the dampening. Also I have full steel skids, steel sliders, and soon front lo pro steel bumper with winch. It's the only reason I went with 650.... if not I would've just went with 600 or stock 550 springs instead.
Eibach Pro Kit with OME895E rear coils and 1" body lift with 295/70R17 MTZP3 on 17x8.5 XD Grenade Wheels. Also custom fit the TRD skid for the KDSS to work
MaximussK
