IronManKansas
It look like it was done that way so the the gusset would sit up flush with the tab.
Regarding that drivers' side gusset: - the triangular tab this bolts to, on top of the horizontal leg, is only welded on one side on mine. I would have thought that is a pretty highly stressed joint, and should be welded both sides. Am I, as usual, over-thinking it, and worrying about nothing?
I could weld it myself, but then I lose the advantages of powder coating!
(Just to clarify, I DO realize this tab is only on the drivers' side, but am wondering if that single tab should be double welded?)
Thought it was weird that one side was different from the other. Guess I didn't notice the gusset on the passenger side.
Just got my shockworks slider this week and installed them. Question.. How important is the gusset on the drivers side? (step 6: in the instructions) Do we really need it? I don't have any lines that run through there like the illustrations.
was an easy install, all was simple until I found out I put in the long bolt in the passenger side and needed it for the gas tank. Crap had to go through each bolt to find out which one it was and of course it was the last one I looked at. Might as well done the install twice but was great practice and not once was I mad since I was so happy to get these bad boys on.
What is the TE trail edition trim?
I'm new at mods in general. Got into it late in life. The gas tank strap removal is a little scary. And do you really have to drill to install these? If so, I might look for something else.
Then again, maybe I'm being stupid. LOL.
I just finished installing the slider last night. How important is it if I didn't drill out and put a bolt in on the passenger front side bottom?
