Silver 4runners (pics)
Which bike rack is that?
Its a Yakima Holdup 2" and I love it! It holds my 2 mountain bikes perfectly. Of course it folds up toward the hatch when not in use, but it also folds down past parallel (away from the hatch) so you can open the hatch and get to anything back there, even with bikes on it!
The 2 things I really like about the rack are:
1) It holds the bikes upright from the front and rear tires rather than the bikes hanging from the frame like a lot of other racks do. Hanging your bike will eventually damage your frame over time and also you have to worry about swaying of the bikes on quick stops, etc.
2) It has very nice and simple built-in locking cables for your bikes so you don't have to worry so much when you leave them. It is only a small cable that goes around the frame of the bike, but it gives you a small piece of mind if you have to run into the store or make some other fairly quick stop for something.
Its a little pricey (but what about mountain bikes isn't pricey). I got mine off Amazon and saved 50 bucks so that helped a little. Here is a link to read more about it https://www.yakima.com/holdup-2-2
What size tires are those?
They are BFG All Terrain KO2's in 275/70/17. I only wanted to go up one size from stock, so I wouldn't have to worry about the tires rubbing. On road, Off Road, forward, reverse, full turn of steering wheel, or full flex of suspension and haven't had a single issue.
Here is a better pic so you can see from the side how much of the wheel well they take up.
Is this with stock suspension? Looks good!
Thanks man... Appreciate it! I actually have Bilstein 5100's all around but I do have stock springs. The front Bilstein are set to .85" so there is still a very slight rake. With that said, the rear is stock height (since the springs are stock) and the front is raised approximately 1".
Heres a pic for stock comparison on the rake...
What tires??? Never mind. Just looked a couple posts up.
Looks great! I think I'm gonna put my 5100s at 1.75 and then try and fit the 34x10.5s. I'll prolly have to do the BMC, etc
Are you positive those tires will fit at 1.75? I had 285s at 2.5 and I get they're like an inch wider but I was very close in turning, you might be rubbing quite a bit with less of a lift
Sent from my HTC6545LVW using Tapatalk
That's why he stated he may have to do a BMC, etc. to get the tires to fit. When he says BMC I think he is referring to a Body Mount Chop. Sounds like he is willing to make room for them no matter what. But you are right... he definitely has got to do something or they will be rubbing for sure.
I know there's a member on here with 35s and a 3" lift guess I underestimated the BMC might have to look into that lol
Stock TE 2016 w/KDSS. Looking to add a lift, new tires and sliders and learn how to work on the car.
I am looking at the Toytec BOSS lift. Anyone in the Bay Area willing to lend a hand with the suspension/lift? I am happy to provide beverages, food, and pass the favor to future newbies.
Thanks,
Yuri
Thanks,
Yuri
If you're on the TW forum, in the Norcal section, they have MOD day where everyone come and meet up with any wrenching. There's actually one this Sat.
tuṣṭāva
