Desert Fox
I bought a set of Shockwork sliders from a fellow 4th gen owner. They were designed for non-XREAS and I have XREAS.
The difference is that the non-XREAS have a gusset that gets in the way of the XREAS lines. All I had to do is grind off the gussett and they worked.
When installing the sliders you have to take the XREAS lines out of the plastic clips that hold it to the frame. There are 4 on each side of my 2003. 3 of the 4 clips had to be removed because they lined up with where the sliders bolted on. I was able to clip the line in the 4th clip after installing the slider. The part of the slider that attaches to the frame slides under the XREAS lines, a bolt goes through the slider bracket on top of the frame and that is what secures the slider to the frame. It is a extremely tight fit. I had to smooth out some of the weld on the frame with my grinder to get the slider to fit.
On my 2003 the driverside was a royal PIA, the passenger side was cake.
The driverside has other lines (interior side of the frame rail) in the way where you have to put a bolt in and the bolt in the rear goes where the gas tank is so it is very hard to access.
If you go this route have a lot of patience and start with the driverside.
I dont see the sliders helping with car dings. They dont stick out that far. If they did I would be hitting my legs on them.
