Launch control?
Sick sliders though!
Launch controls will be attached in line to left and right front brakes. They allow me to engage the brakes independently from each other.
How is this useful you may ask?
Well lets say that you have one front tire in the air and the other on the ground. Push the button and lock the brake on the wheel in the air. Due to the mechanics of an open diff, this will instead of diverting power to the spinning wheel it diverts power to the wheel still on the ground. Kind of like a simulated locker
You shall see in Moab bud
Am I the only one who realizes that this 4Runner is a 2001 model?
The Toyota VSC/Trac system is factory equipment on this model year, and the traction control side of that system already performs the function he's going for, in the same way he's trying to do it. It actually works pretty well if you give it a chance.
The mod sounds good in theory, but I'm not sure it's going to work any better than the existing Trac system. I can picture it being kind of cumbersome, especially because the only time it will be necessary is when a front tire is off the ground... not exactly a time you want to be messing around with a switch and taking your attention off the task at hand.
Unlike the factory traction control system, which will automatically STOP braking the wheel in question, this system will have to be manually switched on/off at each front corner, each time it is needed.
I'm about to order the sliders also. Question, where will you get them welded on? I'm unsure what type of shop to look for to weld on sliders.
The theory works, and i've used it before in situation where front is slipping, have your foot on the break 50% to stop the loose wheel from spinning then throttle to give power to the wheel with most traction. but you can never stop the 1 wheel independently with that. if this works well i'll be doing it to mine as well. assumming i still have ifs next year.
Like a poor man's ATRAC. I'm intrigued.
cool. it should work just fine. Like a manual traction control on vehicles that use the ABS for it instead of limiting throttle.
Only a guy who really cares for his truck gear would lay it on his bed. Good man.
