Smokie's 99 sport build thread.
Smokie
My turn! :banana:
I'll be updating this post with pictures and descriptions as the parts start rolling in. I plan on doing all the work myself, except for the installation of the differential parts (I'd rather leave that to a professional).
Starting off with a stock 99 sr5 sport/Highlander 4x4 v6 5spd. 271,000 on the odometer. Vehicle has been well maintained, and serviced regularly. Checked compression on all cylinders and are all in the 140 +/- 5psi range.
BDCC79B1-960A-4207-966D-D3334E027B01-8608-000009696808CAA2_zps0d9e36f9.jpg~original
Have already changed out the front brakes to the Tundra 13WL's, installed JL/Rockford/Kicker/JVC sound system, gotta have my music.
Parts ordered and incoming.
New TRD supercharger kit
SS 1.2 lift rebuildable 2.0
DOM rear lower links
URD rear O2 simulator
URD 7th injector kit
Innovate 3851 boost/vacuum gauge
URD 2.2 inch supergrip pulley
Doug Thorley headers
4.56 Sierra ring and pinion front and rear
ARB front and rear air lockers
ARB Compressor (free with lockers)
285/75 16 Mastercraft courser MXT tires X5
FN 5-star 16x8 -25 offset gunmetal X5 with lugs (Thanks Dustin!!)
1" body lift from Shootmymime (Thanks man!)
Wade in channel vent visors
airaid intake tube
LR Upper control arms
Hilux surf field monitor
Maintenance parts ordered...
OEM lower ball joints
OEM outer tie rod ends
NGK spark plugs
NGK plug wires
OEM MAF
OEM fuel gauge sending unit
OEM Engine mounts
OEM Trans mount
OEM lower control arm bushings
OEM rear U joint
OEM sway bar end links-front
OEM sway bar bushings
OEM CV boots
I figure it should take around a month to receive all the parts, and get them installed. Any tips/tricks/hints greatly appreciated!
Woot, first part arrived, factory fresh!
81BF410C-E183-47BA-9F03-B3FFD22C8158-15001-00000F2A83A1949A_zps306e1czy.jpg~original
URD order came in today, more go fast parts. :D
2C2A4E37-BA53-4671-99F4-1ED4F730221D-17392-0000110930CF135E_zpsiydyh8f8.jpg~original
Tires came in today.
4F96A86C-480A-4758-B6B1-0464FDA0B72C-19073-0000123E2367B742_zpsutcplixq.jpg~original
4/20 Spent 4 hours taking unnecessary stuff out the way, and unbolting the exhaust manifolds. Damn Toyota was hateful when they designed the angles on these! lol Thank God for sawzalls.
8083B6A8-4C14-408A-82A4-8A310EAD52E9-21445-000014AC5D220AA8_zpshtc4jeco.jpg~original
4/21 Headers installed
025AC684-FDBE-4B37-A622-5B62050D4FEE-21670-000014C646FC399E_zpskn7c1aqz.jpg~original
4/22 Supercharger installed
9B5D2457-D9FD-4847-9973-9BB25CFFE91B-22175-00001541158CC91F_zps4hdikhhx.jpg~original
4/23 URD PCU installed and wired up.
C2E6F1F2-FF5D-4C5F-8629-EFBB6BEF3A3A-22784-000015C1253649DD_zpsgourxqhb.jpg~original
Rims/tires mounted and balanced.
CD2DD8C4-19FD-4A7D-BF2B-8903716821AF-22852-000015CC680CF9DD_zps19pttf5b.jpg~original
4/24 Welded up and installed cat pipe
B8ACFADD-C5BC-43B0-9A80-2EE4729B158A-23388-0000163EFD16EF99_zpsr51qkdwk.jpg~original
4/30 Body and suspension lift installed, put wheels/tires on.
7CB83843-22F5-46B3-BF27-4765E234B59C-27651-00001986B8AA6B51_zpsmdtgcqag.jpg~original
Hey Smokie, This is the Bandit.
That's a nice list of parts you've got coming in. Can't wait to see some pics.
You and me both Bandit! I'm stoked about this vehicle, hoping it turns out to be a solid performer. It won't be as pretty as yours for sure, I'm leaving the factory scratches and dings on it lol (previous owner). It'll just make me baby it when I'm out on trails a bit less.
With that being said, just got a call from the guard shack that I had a delivery from TRD....wonder what that could be. :frog:
Anyone know of a tuning/dyno shop in houston that is familiar with these engines?:shrug:
I'm not even going to attempt to dig into this programmer without someone holding my hand.
Holy moly, I gotta see this.
Should have some tear down/add on's coming this week. Been waiting for a break with work to have some time to do all the mods at once.
Not going to lie, I'm pretty bummed about having to drive one of the others, this truck is a blast to run around with!:rockon:
Good lord, man. Why do maintenance parts get me such a boner now? I must be getting old
Hey, it's like putting a breath of new life into a vehicle when you change stuff like that, I know the feeling! I plan on keeping this vehicle for as long as I can possibly keep it on the road, so I want to treat it right.
Side note, I had to laugh at what Barbara from TRDparts4u said. I called in to order some stuff and she said "ok, we have two different warehouses, do you want vroom-vroom parts or the icky boring parts?" I liked to fell out of my chair.
AWesome! Any plans for meth?
Not as of yet, I'm going to see how it runs with the 7th installed and a tune first.
Hopefully she holds together, it's got 270k+ on the motor. Did a compression test and it read 135-140 on all cylinders, hopefully that's decent enough. Just going to have to keep a close eye on it, make sure I'm not pushing any fuel past the rings into the oil supply. I'm pretty sure that's where the wear is, valve stem seals seem good, no smoke on startup.
I mean, hey, if the engine kicks the bucket, itll just give me a reason to build a new one!
Decent progress today so far, got the passenger side manifold and cat tube off, unbolted the drivers side, but ran out of blades for the sawzall. Since I'm not using the stock setup anymore, it's easier for me to just cut it out rather than fighting with the crossover pipe bolts. If anyone is planning on installing headers, I wish you the best of luck lol. The room on the drivers side to work is almost nonexistent.
Pretty tools :)
39D5A4DC-89BA-495E-9525-B9762952A526-21445-000014A097A1317B_zpsnuzbba5h.jpg~original
Parts removed so far.
C32BE34B-2F15-40C6-BCC3-F78D4209FFB8-21445-000014A0A50120BF_zpsujyd4mgn.jpg~original
Passenger side all nekkid (the easy side)
5BA37746-B8CA-44AB-A68F-C316A25C6292-21445-000014A0FDE78EB0_zpsoblkzt9e.jpg~original
Got some new blades, all manifolds removed.
Finally got the headers installed after about 5 hours of cussing. But d*** they sure make things look different! :)
Smokie---About the fuel gauge--Why did you focus on the gauge and not the #3 printed circuit board. My fuel gauge went kaput and changing the sending unit and suction tube did not fix the problem. The PCB is $220 from the dealer--I have not priced the gauge. Any advice??
DED & DED
chasebradshaw
