Smokie's 99 sport build thread.
Smokie---About the fuel gauge--Why did you focus on the gauge and not the #3 printed circuit board. My fuel gauge went kaput and changing the sending unit and suction tube did not fix the problem. The PCB is $220 from the dealer--I have not priced the gauge. Any advice??
DED & DED
To be completely honest, I'm at a loss as to what part is actually bad, the gauge itself or the pcb board. I'm leaning towards the board now as it's the most common cause. I already bought a new sending unit, so I know that part will be good at least.
Got the supercharger installed and all lines plumbed today, as well as a new transmission mount. Also tightened down my crossover pipe, and gave the engine bay a minor detailing. Oh, and bolted the 7th injector too.
9B5D2457-D9FD-4847-9973-9BB25CFFE91B-22175-00001541158CC91F_zps4hdikhhx.jpg~original
Tomorrow is install 7th injector ECU module programmable box thingy, and run the lines for the boost gauge.
Wow, so much work you've done so far, and to know that more is to come... can't wait!
Also, that wheel/tire combo is going to look awesome. Looking forward to the pics!
Didn't get as much accomplished today as I wanted to, all the welding machines were tied up so no exhaust. But I did manage to get the urd pcu installed and wires soldered in to the ECU. Also got tires mounted and balanced.
Pic of finished connections
1B8B0207-12FC-41E7-82E6-73F9C20659B4-22784-000015BF2751500F_zpslf6jdhpu.jpg~original
Before tape and shrink tubing.
C2E6F1F2-FF5D-4C5F-8629-EFBB6BEF3A3A-22784-000015C1253649DD_zpsgourxqhb.jpg~original
Body lift from shootmymime should arrive tomorrow, and suspension lift will be here on Monday.
I am at the same point. Trying o buy a used PCB. If it works great--if not I will try to get it rebuild. Do you know anyone who rebuilds/services the PCB? Thanks for the response. Installing the headers looks like a real chore--how many hours did it take? It is on my to do list along with new suspension.
Keep on Keeping on--
AWesome! Any plans for meth?
That is an interesting approach to tackle a large project.
Would "speed" things right along though.
Don't spike it, snort it or smoke it though.
Just swallow it wrapped in a thin layer of tissue.
And don't get hooked on it! :nono:
Got the cat pipes fitted up welded, and all bolted on. Punched out the cats as well, we'll see how that works out lol.
Fitting and tack welding
98EC4353-81C6-4E24-8178-C81D59241FD5-23388-0000163F149FE1F5_zpste47aavp.jpg~original
Finished cat pipe ready to install.
B8ACFADD-C5BC-43B0-9A80-2EE4729B158A-23388-0000163EFD16EF99_zpsr51qkdwk.jpg~original
Santa brought me a 1" body lift today. Thanks shootmymime, looks great!
0C71DBFB-1215-46F6-83F9-DA7D972D328E-23388-0000163F077CE5DA_zpsbdr2mgzd.jpg~original
Also plumbed the boost sensing line to the supercharger and ran the fuel hose for the 7th inj. Dropped the fuel tank for fuel pump installation, and welded my rear lower link mount. (Was cracked from previous owner)
Unfortunately I couldn't begin to tell you where to find someone that would service the pcb. You might be able to have toyota reprogram it for your specific mileage, but they may be funny about that.
Total hours spent working on removing the old exhaust manifolds and cat pipe, then reinstalling the headers and modifying the cat pipe....around 18 hours. I would suggest spraying everything down with a GOOD penetrating oil (kroil,pb blaster,etc) a day before starting the removal. Also, have a sawzall with 8" blades handy in case you get to a bolt that just won't come off.
All the manifold bolts came out easy peasy, it was the ones that bolt the manifolds to the crossover pipe that really are going to give you hell.
Tools that really helped me out for removal,
Sawzall w/8" blades
3/8" drive breaker bar
12" x 3/8" drive extension with wobble end
12" x 3/8" drive extension with straight end
1" x 3/8" drive extension (used a lot)
Angled long handle 3/8" drive ratchet with swivel head
Female Torx sockets (for removing manifold studs)
3/8" drive stubby ratchet with swivel head
Set of metric swivel sockets
3/8" to 1/4" drive adapter
1/4" to 3/8" drive adapter
1/4" and 3/8" drive swivel adapters
Set of metric ratchet wrenches
1/4" drive ratchet w/deep sockets
6" x 1/4" drive extension
3/8" drive metric deep sockets
Set of various length pry bars.
Ball peen hammer
When you go back on with the headers, you'll quickly find out just how big your arms are, and how good you are at reaching behind your head and wrenching in the blind while laying under the vehicle.
When you get to that time, shoot me a pm, I'll give you any tips that helped me out if you get stuck.
Sorry for the lack of updates, been putting in some long hours working on this girl.
Front ready for coilovers, new lbjs and tie rods.
3C20DEBD-995D-4822-86F7-72C8B7A8B87A-27651-00001987420AD4F2_zpsqyzqkl1w.jpg~original
rear suspension ready.
A56C284E-FA98-4D59-B828-36F73D193B76-27651-000019869046EA3E_zpsba4bk9db.jpg~original
pile of parts removed.
F0DC31CE-5F02-4266-8BA3-48E9BB454754-27651-00001986AE148558_zps092xm5og.jpg~original
Shiny pile of new parts from Sonoran Steel :tongue1:
2D944F70-F4E9-4A69-996A-E0E3E53FF4D1-27651-0000198698FB9756_zpsul8wb0vw.jpg~original
Spare tire carrier modified to fit 33, still not sure which way I'm going with this.
1D13C188-09C3-4892-833A-17AB5820E34C-27651-00001986A2296FAC_zpslbvnefr9.jpg~original
I'm totally patenting this technique for installing rear upper shock nuts! lol
7BA149CC-00B7-4404-AAE9-89B24687B24B-27651-0000198A6A5971A1_zpsnpdcuaw9.jpg~original
Parts installed, needs moar rubber underneath!
10EDBEAB-2F99-4C05-977E-476283F28E99-27651-00001989DE6D655F_zps6ivtb5lk.jpg~original
Finally sitting on tires again. It's fun hopping up into it now, and talk about ground clearance! So glad I did this lift.
7CB83843-22F5-46B3-BF27-4765E234B59C-27651-00001986B8AA6B51_zpsmdtgcqag.jpg~original
Took it for a test drive around the yard before bringing it in for alignment, and the MAF sensor kicked the bucket. Well, there goes another 200 bucks. Picked up another one and she runs beautiful now, no pinging, plenty of power, and drives straight as an arrow. Just have to take care of some airflow check engine lights and I'll be gtg.
Dropped my girl off at the shop today, I hope they take good care of her. They are the best name in town with plenty of happy customers, so it should be good.
They talked me out of using the Yukon gears, as they have had problems with them in the past, warranties and such. Was told that there hasn't been a single problem with these since they started using the brand. We'll see.
Gears, air lockers, and compressor.
E773B3CF-16F6-44A7-8FB3-E6D5BCD0C423-29436-00001AF2DD43073E_zps5kgwwoj8.jpg~original
chasebradshaw
