Snow in Maine, 2000 4runner limited
I was pretty excited, picked up the truck and was a little worried initially, at 65 i was scared to drive it, the vibrations and terrible ride quality made me question my purchase. But after swapping the suspension out the next day and throwing on the tires, I was in love. The wheels came unbalanced and surprisingly very little vibration, after a static balance she has a small hum at 70-73 and dead quiet to 85. The wheels are steel and add a lot of weight. 39 bolts per wheel. Especially being 9" wide. I would like to regear to 488 at some point. I also wouldn't mind putting some all terrains on the stock wheels.
Ok having an issue with 4wd and 'awd' will not engage the t case or front diff. Vsv has vacuum and switches when 4wd button is pushed. But the t case shifts to neutral I can do this at a stand still or on the fly same happens and I have no drive. If I switch the vsv hoses the t case will still not engage. Now if I shift to 4HL I'm still in 2wd front diff does not engage. But I still have rwd. Same happens when I shift to 4Lo. Still 2wd and low range. What would cause this?
Little more info. Car not running key in on position f/r driveshafts are connected. But I still can roll the truck in park. Now I shift to 4hi f/r driveshafts locked and can not roll truck in park. But I start the truck and drive In loose terrain only rear wheels spin (4hi engaged)
Sound to me like a center diff lock issue, not really sure what would cause this as you seem to have the vacuum lines figured out. It could be the locking servo if its push-button. Wish I could help more, good luck!
Why against Fluid Film? (just curious) I'm finding the stuff to be magic. I vote for both. Of course, I'm in Vermont, land of brine saturated roads.
Just curious, but I heard that brine is less harsh than the salt. I have always heard about Vermont being the worst with rust nightmares so I'm guessing whatever I heard was wrong.
OP, that thing is clean! Spray it with Fluidfilm if you plan to drive it in those Northeast winters.
I' coated the entire underside with a thick coat of fluid film on Saturday. Went on easy, it's like spraying honey on the frame and feels waxy.
I don't know if it's the Vermont climate combined with the brine usage or what, but it's a complete nightmare. Constantly chasing rust. It seems to have increased when they made the switch from salt to brine so I just assumed it was the culprit.
NJ started using brine when they ran out of salt last winter. I noticed that my gas tank skid plate had a fair bit more surface rust after that winter. I think the brine might very well be worse. Whatever it is they are using, I hate it. I hate living in the northeast with these harsh winters in general.
I did [MENTION=14772]shootmymime[/MENTION] purchased it from you about 3 weeks ago. I haven't installed it yet. Mainly got it just as a precautionary if I needed extra clearance for the 9" wide wheels. But after the pinch weld mod I don't rub even at full lock. Still on the fence as to installing it she looks pretty good as of now and sits high enough for me.
well cool-e-o.
Sorry i did not remember your name, i get so many orders its hard to keep track of usernames, i would have recognized your name and address tho.
Thanks for the purchase and maybe you will git the itch to be a little taller and install it. :beer:
Here's an update, fixed my limited's intermittent controls of the hvac still need to troubleshoot the door locks not locking. Pretty sure I know where to look just not sure yet how to fix it besides replace the interior fuse block.
I've ordered some led light bars, 1 20" and three 3" Cree led. Waiting on them to arrive.
http://www.avecproducts.com/products/light-bars
Better prices here:
http://www.tacomaworld.com/forum/buy-sell-trade/336748-avec-led-bars-tw-pricing.html
Picked this up today off craigslist for 150
f0a2eb37e3beaef74f6424b386c1a4ef.jpg~original
And this, it's for a land rover but I think I can use it as a base for a rear bumper.
417944e45e7b865e4fe34139cd0a6ca7.jpg~original
The town is working on repaving the road so it's impossible to keep a white truck clean
6c86d9e6a2f71e02217929c4ab7d9912.jpg~original
Made a template for a cb radio and extra reverse light bracket. Now to make it out of steel.
025911e6f4f553ded4e979d6b708cea7.jpg~original
c14b58932391c251320a48143d8e3edf.jpg~original
Picked up 2 sets of super heavy duty sliders for a cargo drawer system. Looks like I'll be busy this winter fabricating.
2e71085c58b52430bc5cf0ad2c6e1c7e.jpg~original
Also added a red led in the map light surround, it's on when the truck is and is nice to have a little light inside the cab while driving. Makes it easy to see what I'm grabbing without loosing my night vision.
2d8b173ff231818a25a66370d703ee33.jpg~original
And lastly won this on eBay for 30 shipped, but all it's done is (I believe) confirm my front diff does engage but I don't think the front driveshaft is connecting to the front diff. Please help me out in my other thread, I really don't want to buy a front diff rebuild if I don't have to.
715a1802a7912dc1c58c39c37851bbf2.jpg~original
I did a circle, started by wanting to do a dual battery setup. Decided to run one large deep cycle battery. Tested dc voltage it was low but it was sitting for a while. Got it all installed and charged, truck fired like a champ! 4hrs later not the story, click, click, click. 10.3vdc and dropping. After doing some tests, she is done. So I put the old battery back in :/
5aad2df06442e2c67f0f8eeb0430e351.jpg~original
Old
C9CB06A9-539E-4052-98B3-C461D7BE83DA.jpg~original
Also cut steel for cb antenna, and rear facing led light. And cut steel for ditch lights. Lastly some protection for the lower links
59533015327a9f4a23aa8bad1cad8839.jpg~original
A7D1D8C4-BF21-4EF6-BFA4-76A9567FE24E.jpg~original
All in all, not a complete loss of a day.
Update: I've done about 2hrs of stick welding. I'm having a coworker teach me. So far it's been fun but still have a long way to go.
The brackets sit until my welds stop looking like ass.
Spent a few hrs under the truck messing with the front diff actuator and managed to fix the 4wd!! After blowing multiple Subaru transmissions, Transmission fluid is one smell I will never like and never forget.
I purchased 4 Avec light bars, 1-20" and 3-3" cubes. A little mixup in the shipping dept sent me a spot 20" instead of a combo but Mikes a good guy and is making it right.
I've mounted it stealthily behind the grill.
7ecab1c64f9a98ecbcbee861858d950b.jpg~original
daaaaaammmmmnnnn that is one clean 3rd Gen! i was scrolling thru the pics thinking "how on earth can that thing be so rust-free?"—and then i saw the Cali plates. :D
nice grab. that thing is beautiful.
hey, anyone have a recommendation for a trusted shop that can do/has done a Toyota body-mount chop for a fellow Mainer? i have some pretty good rubbing since mounting new wheels and 285/70 Mickey Thompsons and i think a BMC is gonna be required
Where are you in Maine? I just teach myself how to do everything. It's way better than relying on someone else to fix or mod the truck.
After fixing the 4wd issue I did some mild testing to find where the tires rub.
B38F7287-0DB3-4F80-A119-6B0AD05352BD.jpg~original
E1FFF670-68A4-45EF-A2BF-CFD5C743AC9F.jpg~original
FAC740DE-1D12-4DBC-9554-918546E111F7.jpg~original
F5C207C6-A75F-42C1-BB04-614828D6DF09.jpg~original
She stuffs them pretty good, I rub on the rear mudflaps so they will go soon
