So after my milkshake fiasco...need input!
Riders of Lohan
Long story short, my truck milkshaked about a month ago. I had a guy rebuild it, replace the torque converter, and drop in a new radiator.
Right after that, my tcase was leaking. Had him do all three seals. Top seal was actually defective when he put it on, so it started leaking again right away.
During this time i periodically had the car find no gear when switching from 2-3. It would just kinda drop into neutral until I popped it into 2 or slowed down enough for it to change back down into 1 or 2.
My guy checked the valve body and said it was tight on the overdrive shaft. He replaced the valve body and I have the truck back. Don't really know wtf that means. The 2-3 shift still feels a little sloppy but I haven't had the truck fail to find third yet.
Yesterday I drove the car at least an hour in 90 degrees and it started to get a btg sluggish on the shifts. I also noticed the base of the gear selector was pretty hot, but I guess I never paid attention to how hot it was before, but does that sound normal.
Final question - my truck never used to roll back on inclines on hills. Now it does sometimes. I rolled backwards down a driveway in drive no problem - it would go as far as I let it. 15ft, whatever. Anyone experience this? Could this be from heat of the fluid and the torque converter or does it sound like an issue?
No warning lights came on and I do not have a scan gauge to know what temp the trans got up to
I've noticed that my transmission can't find the correct gear and jumps around when I don't have the gear selector properly in drive. Maybe the linkage from the selector to the trans isn't adjusted quite right?
Also, was the cost of a rebuild and new torque converter a better deal than replacing the transmission with a low mileage replacement? I'm just not sure how reliable a rebuild would be after coolant got in there.
It remains to be seen if the cost was worth it. $4700 at the dealer. $3600 through this guy. He rebuilt essentially everything other than the bell housing. I was basically out of options and needed the truck back. It's my dd
In retrospect I may have been able to buy a unit and have him do it, but I think I would have spent close to 2 grand on that gamble and at least this way I have a 1 year warranty on parts and work.
A little late but I have used98 trans for sale with98000.miles
That worked fine when car was totaled , 500.00 plus ship if anyone
Needs
Yeah the base around shifter and area that holds your drinks gets plenty warm on long trips, good for coffee not so much for cold drinks.
Not sure about the roll back, but mine will do it on a good san diego/frisco hill!
If you regularly climb 3-6 degree stuff, I recommend turning the OD off while climbing, it will cool the trans fluid down considerably (e.g. 220 down to 195).
If i were you, I'd flush the fluid after a 1000-2000 miles on the new tranny and run a magnefine on it. Cheap insurance....Luck!
kimyuseung77
