So Cal 4Runner BS Thread
Anyone familiar with Slide Lake Campground in SBNF? Or that area in general as it looks like there are a few areas for primitive camping. I'm planning to head up for a quick trip this Saturday.
Yeah I’ve camped there a few times. Not much up there besides the upper portion of Bear Creek. There is a better spot off of 1N09 where Bear Creek meets up with the Santa Ana River. You can camp right next to the creek and hike down about 1/4 mile to the aqueduct where the creek and river meet. Might be a little too cold to take a dip in the water but it’s nice during the summer.
The better spot is a little harder to get so try to get there early before someone else snags it. It’s the spot right before the bridge. There is a big tree with shade too.
Got it. Thanks for the info. I saw that area you mentioned as well using satellite view. No real agenda, I just need to satisfy a curiosity itch. Have you taken 1n09 all the way to 330? There looks to be a variety of forks along the way.
Yeah I’ve explored pretty much all the trails on that side of the mountain. There are some cool views up there. There is a spot called Keller Cliffs on 1N09 between Bear Creek and 1N16. It’s pretty cool to stop and check out. Not a whole lot going on up there but it’s cool to cruise around the area just to see everything.
Hey guys I'm new to this forum. I've looked on this forum to answer a lot of questions I've had in the past but never made an account because I could always find my answers to the questions I have had. So I had been doing some looking around to see what people had suggested for removable doors. I finally settled to cut my hinge pins and make some removable pins. My next problem was the wiring, I have electric windows and locks and mirrors so as you can imagine there was a lot of wires going in and out of the doors. I wired harnesses and they are weatherproof. My last problem is that my windows themselves do not physically roll up, I've heard things like reset your actuators or regulators but I have no clue where they are and how I would reset them or anything like that. I'd really appreciate the help, I haven't been able to roll up both of my driver side windows for a couple months and all of my other windows won't roll down, and I'm guessing all of you know how much it sucks if your back window doesn't roll down. Any help would be greatly appreciated!!
Most people here don't have 2nd gens. You'd be better off asking in the classic 4runner subforum or on various 4runner facebook pages. I think you'd probably have to remove your door cards to get to the window stuff. I'm not sure cause I managed to get one with window cranks lol.
did this happen after you cut the wires?
here's a good vid on rear window maintenance
https://www.youtube.com/watch?v=cG0ScBpmqkI
Hey guys I picked up some used sliders and there are a few scratches in the powder coat to bare metal and little rust spots. Should I sand these rust spots and use touch up paint or can I just leave it and use them? I don't want the rust to ruin the whole sliders.
Hit it with a sander real quick or a wire brush, then spray it and call it a day.
Shit, all this talk about sliders I should pull mine off while I'm taking the rest of the rig apart and repaint them, then have them welded back on.
Why weld if you're inevitably going to need to repaint? Just a thought.
Because I actually use my sliders and the RCI bolt on setup isn't that sturdy with a habit of moving up and blocking the doors after they've had the weight of the vehicle on them. I also had one of the first runs when they first came out for the 4th gens and they weren't angled correctly so the bottom of my doors rub the paint off whenever I open/close the doors. They need to be brought down but there's not enough adjustment without shimming them to get them to stay. Rather just get them welded.
roger that
maybe add some gussets to make em stronger when you weld em back on
X2 that's what I was thinking...especially the way ol Danny boy uses those sliders lol
Hey [MENTION=142231]Big V[/MENTION] I forgot to ask you when I saw you, are you running just a 4.7 single case? how do you like it, as in do you wish woulda spent more cash and went straight to a double case setup from the beginning
It has to do with the way the sliders bolt on. The slots for the carriage bolts alot an up and down adjustment to position the sliders where you want them. When you put the weight of the vehicle on the sliders (hi lift, boulder, whatever) it slides them in the slot. I can usually just bounce on them a couple times and get the doors to clear again but it's really annoying. Once welded on, should stop all of that movement period. Otherwise they're very sturdy sliders.
Single case...I love the 4.7lo, but I wish I had the stock 2.28 for easy trails, the 4.7 with 5.29s and 5spd tranny get a bit too slow, I shift to 2wd alot between obstacles or cruise in 4th gear. Im going with a twin stick setup soon, already have the shifter just need time to install it. If that doesnt work how i want it to then I'll go duals. Im happy with how it performs in low range, not sure if i'd ever feel the need to double down
Gears are getting delivered on Tuesday. :banana::banana::banana::banana:
And I may have also added a front locker while I was at it. :spy:
Nice!! Speaking of that...look we're matchies
Crookedcat
