So I finally got around to installing the SPOD this past weekend
toppyjai
Evening all my 4Runner heads! I finally had time this past weekend and installed the SPOD. It was a fairly easy job (2 hours altogether :bounce: ).
here is the SPOD mounted to the fuse cover. I drilled two holes and bolted the SPOD mount to it.
I then ran the SPOD cable through the firewall from inside the cabin. The firewall grommet is located l to the upper left of the brake pedal. I used a coat hanger where i taped up the plug and stuck it through the grommet by cutting it open a little because the plug is just a little bulky.
once the cable was inside, I ran it up the driver's side pillar where I had to take the cover off the A pillar, I used a really thin flat head screwdriver and pried the "SRS" cover off. It comes off really easy. I used a 10mm socket and removed the bolt and pulled the A pillar off from the top with minimal force.
with the A pillar cover removed, I pulled the rubber gasket off the door molding and stuffed the SPOD cable along the side going up.
I then ran the cable up the side of the window and up through the headliner.
This is a pic of the original SPOD switch panel. I removed the switches from the panel because theres no place to mount the entire panel shown.
I then opened the sunglass holder and removed the 2 bolts from the overhead console and pulled it off again with minimal force exposing a pocket where I ran the SPOD cable through.
with the entire overhead panel removed, I then unscrewed the sunglass holder off the panel and began cutting into it with a dremel after carefully measuring the size of the switches that I was going to install into it. After putting the switches in, I put the sunglass holder back into the panel where I then did plug the SPOD cable into the switches and screwed the overhead panel back into place (sorry, forgot to take pics of this step because I was focused on finishing the install).
heres what it looks like with the sunglass holder open.
i plan on replacing the switches shown with these switches that I purchased from otrattw.com once I figure out what plug on the back is for what
I really hope that my write up helps you and gives you an idea on how to install the SPOD giving it a nice clean and somewhat professional looking install. I installed the SPOD to make adding accessories an ease instead of running a million wires through the firewall. By adding the SPOD, theres no need to run wires into the cabin. The add ons can be connected to the SPOD installed into the engine bay.
Nice thread, thanks.
How challenging would this be for a newbie?
What types of accessories do you plan on adding (other than the machine gun & octopus ink)? Would this be for things like winch, fridge & additional lighting?
JD
thank you for the compliment jjdbike! I already installed my ARB compressor into the engine bay and also the led light bar behind the grill. It is very easy to install, just follow my steps and you'll do great!
Looks pretty sweet! I am in the process of designing my set up. Which sPOD did you go with? The Tacoma of FJ Cruiser model? I am planning on running AOB switches and ditching the 6 switch panel
Ive used an SPOD before in a Jeep, but now I plan on using the SPOD, but instead of using the provided switches and wiring setup, I want to use to factory blank switch locations. Any idea how I would go about this
I had this in my Ram. Just sold it though... But it was the SE w/touchscreen .. Best thing you can buy for your vehicle.
Especially with more than 2 accessories and cleaning up the engine bay.
Can pretty much run anything under 30amps.
IMO
I am also curious which model you went with. Any update on this?
Did you ever find out how difficult this is to do?
I used the standard one for a jeep wrangler. Sorry for the late reply gentlemen!
I went with the Tacoma model:
Toyota Tacoma sPOD Kit
And the AOB switches:
Toyota Switches -Air On Board
It was not that difficult to do. It took some thinking from a friend who is ASE certified, but it was do-able. I wish I could give you more guidance in that area!
not hard at all with this install after purchasing the standard jeep wrangler spod kit. Simple install. The hardest part was using the dremel to cut the rectangle for the switches.
What mount/bracket is that you used for the spod? any benefit to using that vs just stacking the spod on the fuse box? I am trying to make the most use of the real estate so I just tacked my spod to the top of the fuse box.
DexterShaYang
