Antman
Elite Member
Awesome! I like it- simple and effective. :rockon:
Thank ya sir!
Yesiree Mike! - My front KDSS bar has been "missing" for over a year now. I took it off and never looked back. Im actually looking into ditching the rear KDSS which doesnt do a whole lot now and fabricating in a custom Curry Anti Rock rear sway bar similar to how these guys did it here:
Building A Custom Currie Antirock Sway Bar - 4 Wheel Drive & Sport Utility Magazine
:violin: of course you are what cant you do:nerd:
Aftermarket Backup Camera Added to Factory Nav!!!
Pretty proud of this one. Seeing as how my swing out and spare tire now covered my factory backup camera, I decided to add a new aftermarket one instead of relocating the factory one.
I used an Alpine HCE-155 camera and Alpine's KTX-C10LP license plate holder which also serves as the mount for the camera. Wiring was really not that bad. Simply pulling the nav unit, locating the OEM Video + and Video - inputs, cutting them, and splicing in the new video cable.
I'm starving so I gotta run, if you would like more details, lemme know and I will post more.
Now that this is done, I have a 4 way mobil video switch unit I can use to integrate a front camera, and DVD player in combination with the "anytime reverse camera" mod. That is for another day...
I would like to thank J.A. for his help also!!!
Here are some pics:
Here are some pics:
May I ask, what exactly made you apprehensive about installing them? After I saw you talking about these in the other thread, I was thinking about throwing them in for the hell of it when I install a lift in the rear, but maybe not anymore![]()
Wow, it's a good thing you tested it out so thoroughly; sounds like you'd likely tear a hole in it if you kept them aired up while out on the trails. I guess I am definitely not going to bother with these since I never plan to tow.
If the OME 2896 are the same length as the Icons you have, you would probably more than alleviate the sag with the higher spring rate; I guessimate ~40" static height @ the rear fender (based on your current load you provided in that other thread).
Have you ever thought about trying one of these spacers on the passenger side to fix the unevenness?
OME FJ rear trim spacer - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
No clue on reliability or effectiveness of said spacers, just happened to come across it last time I was browsing for a new suspension.
Or I guess you can start packing on the pounds to induce some drivers side lean after you hop in :hungry:
Next upgrade will be to 10 watt. Talk sbout stupid amount of lumens. Can't wait to get mine. I am going to go with the Wurton 40" soon. Then going to go with a 20" on the front bumper.
Sooooo I played around with the firestone rear air bags this weekend and decided against them. For what I do with my truck, I just don't see them lasting.
Ended up finding some OME 2896 rear coils for cheap so I snagged em, I know a few of you are running the 895 coils with success, anyone running the 896's??? They are the same height with a 58lb increase in spring rate. According to OME, they are made for vehicles carrying up to 440 lbs constantly. I figure I am pretty close to that so I'll give them a shot and see if it aleviates the saggy rear that I am now getting with my Icons.
I have the 896's installed but without any true weight in the rear. I can't stand it! but for what you are doing and having the right kind of load I bet they would work nicely. My issue is that without weight on large bumps I can feel the shocks maxing out and making a bumpy ride. Although when I have gear or a heavy load in the back it settles and rides as well as the front.
I guess I need a rear bumper....
Thanks for the input, good to hear from someone who is actually running those springs!
Can I ask why you went with the 896's instead of the 895's? Was it in anticipation of carrying a bunch of weight or a bumper or something?
Tacos have leaf springs in the rearsales guy convinced me that is what he was running on his rig (old taco) and it rode smooth;
Stupid amount indeed! I couldn't wait to install it so I ran a pigtail off my battery posts last night to see how it looked, it is insane….
I had a pretty lengthy conversation about the whole 5W vs 10W LED thing and it sounded like the 5W LEDS were the way to go. The 10W LED's definitely put out more lumes per emitter, but at the cost of taking up more space = less emitters per given light bar dimension.
Here is a little info from Vision-X.
"Why Xmitter Prime XP
The Xmitter Prime XP Bar achieves the farthest lighting distance and brightest output in the Vision X Light Bar lineup. This is due to the 5-watt LEDs that are placed much closer together on the circuit board than 10-watt LEDs allowing for greater optical control and therefore greatest distance. The Xmitter Prime also makes use of Prime Drive Technology which manages heat levels to prolong the life of the LEDs."
