Softer than normal Sway Bar
SAR_Runner
So, in the process of slowly upgrading/fixing what is wearing out... Has anyone noticed that after they changed to other shocks from XREAS that your sway bar feels really soft? I know that there is a kit for the rear from AntiRock... is there a simple one for the front? I dont want to spend a ton of money on a system that in the end will only get me back to stock... I use my rig for Rally Sweep and we are treating our rigs like Baja Trucks.
Notice the lean, this is only going about 30 mph into a turn and braking. If I do go to stiffer coils and maybe spend a bit more on shocks, will I see an improvment?
Stock fronts are good solid bars but my rear (had XREAS) was a silly hollow bar. I went with aftermarket when it broke. It's nice and hard now.
[MENTION=131371]Yukon4Runner[/MENTION] won't be able to do anything to this! :behindsofa:
The front is hollow as well, a lot of OEM bars seem to be hollow when they get to thicker diameters. I think it has to do with the center not being as critical to torsional forces in larger diameters as much as wall thickness? I could be wrong though.
My front is solid for cetain but my original rear was hollow. It's pretty apparent when lifting them which is hollow and which isn't. I had to cut an old front sway off so I'm sure it's solid.
That's weird... my V8 SE's was hollow:
Damn. Much more significant than the rear but not solid as I remembered, that's what mine looked like. The rear is more like a wire conduit than a truck part which I do remember well since it was recent. Obviously, I can be wrong. :tongue1:
Oh cmon, now you you're just trying to make it dirty!
DionicioLives
