SOLD - Cornfed 1 inch FRONT coil spacer - San Jose, CA
The-Wood
SOLD
1/2" top out spacer for 1" lift. Perfect for leveling the front.
Off of a 4th gen 4runner. But should work for 5th gen as well as FJ cruisers.
Located in San Jose, CA
Do the OEM tophat bolts need to be pressed out and replaced to run longer bolts to install this kit?
Yup. Pretty easy with the no spring compressor method. Done by un bolting the bottom ball joint bracket (not the ball joint itself).
